How is an 76 rear sway bar mounted ?
Dutch924-racer
PostPosted: Fri Apr 25, 2008 3:46 am    Post subject: How is an 76 rear sway bar mounted ? Reply with quote
How is an 1976 18mm rear sway bar mounted ?
Does anyone have pictures ?
937 trackday car
Series 2 engine
951S turbo and intercooler
Fast road camshaft
Chrenan
PostPosted: Fri Apr 25, 2008 4:19 am    Post subject: Reply with quote
No pictures, but as I understand it the mounting is to either trailing arm with no connection to the torsion bar carrier. What this means is that the effective rate of the 18mm sway bar is actually less than the effective rate of the later 14mm sway bar which mounts to the torsion bar carrier.
Dutch924-racer
PostPosted: Fri Apr 25, 2008 5:31 am    Post subject: Reply with quote
But will it fit a later style rear suspension ?
937 trackday car
Series 2 engine
Fast road camshaft
Chrenan
PostPosted: Fri Apr 25, 2008 5:55 am    Post subject: Reply with quote
I doubt it. Why even bother messing around when the 19mm 3 way adjustable M030 rear bar can be had for $150 new?
PostPosted: Fri Apr 25, 2008 8:10 am    Post subject: Reply with quote
I had a early rear bar installed on my early 77 924.
As has already been noted, it mounted to the trailing arms only, using the existing trailing arm to swing plate locations, with slightly longer bolts. The problem with this setup is that it is not as effective as the later center mounted 14, swaybar, and the trailing arm bolts need to be replaced occasionally as the swaybar working literally cuts the mounting bolts in half, sawing through them as the swaybar works as part of normal operation.
PostPosted: Fri Apr 25, 2008 10:08 pm    Post subject: Reply with quote
Exactly as noted; the M030 adjustable rear bar is the way to go. I too had the 18mm early rear bar on my '77.
Vince Ponz
PostPosted: Fri Apr 25, 2008 10:41 pm    Post subject: Reply with quote
Weltmeister adj. rear bar attached to the axle??? I have had it on for the last 12 years and it is still tight.
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock
