Posted: Wed Apr 23, 2008 7:21 am Post subject: 30MM Torsions, Which Springs? |
I'm thinkin' 250, what do you guys think?
(For Shaggy) _________________ Toofah King Bad
Chrenan
Posted: Wed Apr 23, 2008 7:33 am Post subject: |
Maybe a little higher? Effective rate of a 30mm torsion bar on a 924 is 335 lbs. Unless they are hollow, then it is 292 lbs. _________________ 1987 951 - M193 Version for Japan |
Posted: Wed Apr 23, 2008 8:36 am Post subject: |
That's quite low - I ran 400, 350 might also suit you. _________________ Vaughan Scott
Posted: Wed Apr 23, 2008 9:03 am Post subject: |
Hmm, I guess I should also ask whether I will hate the ride quality of the 30s! _________________ Toofah King Bad
Posted: Wed Apr 23, 2008 9:58 am Post subject: |
I found them to be a bit soft...
...on the track!  _________________ Vaughan Scott
John Brown
Posted: Sat Apr 26, 2008 11:12 pm Post subject: |
| Rasta Monsta wrote: | | Hmm, I guess I should also ask whether I will hate the ride quality of the 30s! |
400 is my recommendation also. And, yes you will (hate the ride quality). _________________ John
80 931 - #931 44Cup
99 Escalade - tows track cars
Posted: Sat Apr 26, 2008 11:47 pm Post subject: |
400 = no street ride quality and loose teeth. _________________ White 87 924S "Ghost"
Posted: Sun Apr 27, 2008 1:29 am Post subject: |
400 wont be that stiff. I have driven a 931 with 700 at the front. That was pretty stiff, a bit to much for a street car. Harsh ride quality is mostly due to the damper stetup. _________________ 1980 924 Turbo
Posted: Sun Apr 27, 2008 1:39 am Post subject: |
How are the roads in Sweden?
Over here this is normal:
Vince Ponz
Posted: Sun Apr 27, 2008 3:03 am Post subject: |
WOW, you still have dinosaur footprints in your town. _________________ "Never let them see you sweat"
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock |
-nick
Posted: Sun Apr 27, 2008 3:41 am Post subject: |
We've got dinosaurs in Boston too
I ran 25.5mm rear bars with 200# front springs on a '77 and I felt it was not pleasant on city streets. It was a couple hundred pounds lighter than a 931, but 400# & 30mm would be torture in any model.
Right now I'm running 200# fronts with the stock 23.5 torsions with bilsteins and I feel like it's just the right balance between pleasant in the city and responsive in the turns. Just food for thought. _________________ 1980 931S
1991 964 C4 Cabriolet |
Posted: Sun Apr 27, 2008 1:19 pm Post subject: |
Ugh, there are NO roads that look like that around here. Seldom freezes, temperature variations are quite low compared to other places.
I'm goin for it. _________________ Toofah King Bad
Posted: Sun Apr 27, 2008 2:03 pm Post subject: |
Shaggy will become a one driver car..... _________________ White 87 924S "Ghost"
Splineless
Posted: Sun May 18, 2008 1:06 am Post subject: |
| Quote: | | Right now I'm running 200# fronts with the stock 23.5 torsions with bilsteins and I feel like it's just the right balance between pleasant in the city and responsive in the turns. Just food for thought. |
I'm just across the river from you and was wondering about which bars to use with 200# springs I just bought. I was thinking I'd have to go thicker for balance. Glad to hear from someone with 1st hand experience. I'll stick with what I have - just need a pair of Bilsteins. Thanks. |
