Changed my mind, supercharger time.
PwrGTOGuy
PostPosted: Tue Apr 15, 2008 9:49 am    Post subject: Changed my mind, supercharger time. Reply with quote
I figured since i'm going through all of the trouble of doing the serpentine belt conversion, maybe i'll just run a nice supercharger as opposed to a turbo... i've owned, turbos, large displacement v8's (ahhhhh, my 6.0liter gto engine, mmmm, torque)
but, I haven't owned a supercharged engine yet... so how about now..
endwrench, you are using a whipple type, how long is your snout, do you have any good pictures of you placement you could post up?
TIA
Pat
endwrench
PostPosted: Tue Apr 15, 2008 12:22 pm    Post subject: Reply with quote
Allright!! You wont be sorry!
These are the only pictures I could find for now. I'll post some more later if needed of the way it looks now. The lower mount looks a little cobbled but I didn't really have a plan before I started on it. Pretty much the way I fab everything now because i get to hung up on the plan instead of what might be easier.
Yes, I'm running a 1.6L Whipple Charger. It is a bit large so it is not actually running in its most efficiant range yet. They are designed to be twisted very fast. I'm running 50% overdrive now and make 10.5lbs of boost at my shift point of 6000rpm. The boost is still building past 11lbs if I hit the rev limiter at 6250rpm. Remember too, mine is a used unit of a Chevy 350 Vortec and had some wear and tear on it. I would not be surprised to see 12-13lbs of boost with a newer unit.
Todd
PostPosted: Tue Apr 15, 2008 12:48 pm    Post subject: Reply with quote
Hmmm....what are your plans for the turbo you have???? LMK.
PwrGTOGuy
PostPosted: Tue Apr 15, 2008 1:01 pm    Post subject: Reply with quote
Going to sell all my turbo stuff... keeping the 951 intercooler though.
Just haven't gotten around to ebay yet.
PostPosted: Tue Apr 15, 2008 10:29 pm    Post subject: Reply with quote
PM sent.
