UnwiredTools programmable WUR
paulc20
PostPosted: Wed Mar 19, 2008 6:16 am    Post subject: UnwiredTools programmable WUR Reply with quote
Has anyone here used the UnwiredTools UTCIS engine management system for Bosch K Jetronic systems?
See here: http://www.unwiredtools.com/utcis.asp
1981 924 Turbo
1986 928S
tuurbo
PostPosted: Wed Mar 19, 2008 6:29 am    Post subject: Reply with quote
Very interesting - but won't your Lambda system try to compensate for anything this system does?
1980 924 turbo, MSD, Meth. Inj, otherwise stock.
paulc20
PostPosted: Wed Mar 19, 2008 8:17 am    Post subject: UnwiredTools programmable WUR Reply with quote
My 1981 Australian delivered car doesn't have a lambda control system, so hopefully it will work OK. I would like to ensure my mixture is rich enough under boost and this should give me control.
1981 924 Turbo
1986 928S
PostPosted: Wed Mar 19, 2008 8:44 am    Post subject: Reply with quote
Umm...here's what the site says:
Unwired Tools' website wrote:
The UTCIS™ hardware component installs in place of the OEM Warm-Up Regulator - it replaces Bosch Warm-Up Regulators used on K-Jetronic™ (with and without Lambda) Gasoline Fuel Injected Engines.
This is MOST definitely worth a phone call and some further investigation. In the words of the Guiness cardboard cutouts, "BRILLIANT!"
PostPosted: Wed Mar 19, 2008 9:18 am    Post subject: Reply with quote
$700, it'd better be brilliant.
PostPosted: Wed Mar 19, 2008 9:19 am    Post subject: Reply with quote
I'd say no, because lambda's control of the A:F mix stops when at WOT (the TPS tells it when you're at WOT).
The lambda system only operates in closed-loop mode when the engine's fully warmed-up and at either idle or a steady part-throttle.
tuurbo
PostPosted: Wed Mar 19, 2008 9:22 am    Post subject: Reply with quote
Ok thanks, that answers that question. Naive question here - So assuming it works brilliantly, isn't the system limited in terms of fuel flow by the CIS and injectors?
PostPosted: Wed Mar 19, 2008 9:24 am    Post subject: Reply with quote
Exactly my thought. The question would be whether it could handle add'l injectors...
That's 1/3 the cost of a properly executed EFI conversion. The non-turbo application is only $299 which is not much more than a rebuilt WUR from Special-T. Worth looking into in my book.
tuurbo
PostPosted: Wed Mar 19, 2008 10:22 am    Post subject: Reply with quote
That's true Ideola - the 924 turbo one at $700 I would like - but I'll wait for someone to try it first
PostPosted: Wed Mar 19, 2008 10:57 am    Post subject: Reply with quote
I'll definitely be looking into this. I'm going to download the software manual and give it a look through. I'll prob'ly send them some questions as well.
My current plan on the UWB project is to setup a rising rate fuel pressure regulator (like one of these) triggered off of a manifold pressure signal. I was planning to plumb in a completely separate fuel circuit (feed line, filter, 40psi pump, FPR, return line) so as not to interfere with or tax the stock setup. That unit is less than $300, and then add in the cost of pump, lines, etc. your still prob'ly less than $700.
However, my approach is basically mimicking the primitive approaches used on the 924 GT / GTR variants before programmable stuff was widely available. Makes it period-appropriate, but I think the UTCIS approach would be the ideal compromise if it's as programmable as the website makes it sound, and if it could control add'l injectors.
In the meantime, Tuurbo, I would think for your situation the $500 setup would be perfect, as it's designed for applications less than 1 bar / 12 psi. It might even be a worthwhile thing to consider on my 941 car, which I eventually plan to intercool and pump up to ~10 psi. Hmmmm....
Time to do some reading. I'll try to give them a ring tomorrow.
PostPosted: Wed Mar 19, 2008 11:30 am    Post subject: Reply with quote
They're using "1 bar" to refer to normal sea-level air pressure. Not to be confused with turbo-boosted manifold pressure of 1 bar (which is actually 2 bar when you add it to normal sea-level atmospheric pressure). In other words, what they're calling "1 bar" shows as zero on a turbo vacuum-boost gauge. -
http://www.unwiredtools.com/utcis.asp#utcisv wrote:
This version includes a Manifold Air Pressure (MAP) Sensor for pressure < 1 bar (ie vacuum).
-But, the 931s' OE Bosch full load enrichment WUR operates only by vacuum, and doesn't "read" anything to the positive pressure side of 0hg (again what they're calling "1 bar"), so the unwiredtools model UTCISV operates off the same range of vacuum signal as the OE Bosch 931 WUR.
The Bosch full load enrichment WUR is in its' enrichment state at 0hg, and is "pulled" toward lean as vacuum increases. In other words, it's normally in enrichment mode, and uses vacuum to lean the mix for idle and part throttle, rather than being normally in the leaner state and using boost pressure to "push" it into enrichment mode.
PostPosted: Wed Mar 19, 2008 11:38 am    Post subject: Reply with quote
Yeah, Smoothie, you're right, I realized that after just completing reading the manual.
Doesn't appear to accommodate add'l injectors...so, in a high output application, one would have to determine the optimum fuel flow and figure out whether the injectors & dizzy could handle the flow, or if supplemental methods would be required.
The $700 unit is the one to get for any serious turbo application because it allows the map to be configured based on both manifold pressure & RPM range. I don't know much about megasquirt, but a cursory glance gives me the impression that this setup is not as granular as MS (i.e. 250 RPM increments vs. 100 RPM increments in MS, I believe). In any event, it's still gotta be better than stock CIS. Perhaps sort of a happy medium. Definitely worth further consideration.
PostPosted: Wed Mar 19, 2008 9:56 pm    Post subject: Reply with quote
Dang, the UTCIS-V would be perfect for my racecar... too bad it's so dayum expensive... Maybe next year. Would be so easy to dial that puppy in on the dyno.
This year at very least I have to get on the dyno and adjust my basic control pressure (as per the UTCIS-G)...
Min
PostPosted: Thu Mar 20, 2008 1:51 am    Post subject: Reply with quote
That always makes me laugh, I guess mine just isn't 'properly executed' *chuckle* still enjoying it and its been what ... 2 years? extremely reliable.
Min
tuurbo
PostPosted: Thu Mar 20, 2008 1:59 am    Post subject: Reply with quote
Not meaning to appear 'whipped' but my wife says No.
lol
We had a long talk about the car, expenses, all that stuff. I've been 're-educated'. Life is certainly different now that she's verbally removed my g'nads.
I love her like crazy and she's been incredibly patient with my hobby - but now I've gotta give back a bit, cool my jets and get the thing running in stock form with just a minor tweak here and there.
But I think you're right Ideola, it appears to be a good way to go! If I give it a six month wait or so and get some reliable performance out of it, she might relent.
