9magazine
Joined: 28 Dec 2005 Posts: 41 Location: Lakeside/Pinetop, Arizona
Posted: Fri Feb 29, 2008 11:30 am Post subject: Popping from exhaust |
Okay what a nice day up here at 7000 feet in the mountains of Northeastern AZ... I have been working on the car most of the day.
I noticed when I take my foot of the gas am getting a popping noise from what I think is the muffler. Timing is set right, and it purrs at 950rpms. Is this the sound of the exhaust manifold going?
Brian
9magazine.com _________________ Brian
9magazine.com
'80 931 5spd - 4bolt wheel |
Posted: Fri Feb 29, 2008 11:33 am Post subject: |
I'd check the anti backfire valve on the intake manifold. _________________ White 87 924S "Ghost"
Vince Ponz
Posted: Sun Mar 02, 2008 7:24 am Post subject: |
You might have a pin hole in the line. Sucks air in and therefore the pop. _________________ "Never let them see you sweat"
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock |
9magazine
Posted: Mon Mar 03, 2008 11:11 pm Post subject: |
Its been cold and off again on again snow this weekend. I did find the part listed in the PET, and then went to find out how much it is. Pelican is showing the Vacuum Limiter at $430.00 its a 930 (turbo 911) part number... anyone have a more affordable source? Am hoping its a bad vacuum line!
Brian
9magazine.com
9magazine
Posted: Mon Mar 03, 2008 11:12 pm Post subject: |
Brian
9magazine.com
Posted: Tue Mar 04, 2008 12:53 am Post subject: |
Snow?? Dang, nothing but sun down here in Phoenix!
Popping will often be caused by too-hot exhaust often caused by running lean or too much timing advance - get more fuel in on the shift, which then pops in the overheated exhaust. So check the mixture, maybe it wants a little richer.
Or, as noted, you could have a small leak. _________________ Vaughan Scott
flosho
Posted: Tue Mar 04, 2008 3:30 am Post subject: |
I've always thought that some popping and crackling from the exhaust is normal. If it is caused by hot exhaust and a lean mixture, it would make sense that when you take your foot off the gas after accelerating a bit, on decel the fuel is cut and you will hear some popping.
Many of the tuner cars pop quite a bit on decel, right from the factory, mostly the turbocharged ones.. Caliber srt4, mazdaspeed3, etc. _________________ [This Space For Rent] |
Posted: Tue Mar 04, 2008 4:23 am Post subject: |
Mine used to pop a bit on decel. Check the joint between the head pipe and cat, and between wastegate and cat. _________________ Toofah King Bad
Posted: Tue Mar 04, 2008 11:22 am Post subject: |
| 9magazine wrote: | | Pelican is showing the Vacuum Limiter at $430.00 its a 930 (turbo 911) part number... anyone have a more affordable source? Am hoping its a bad vacuum line! |
Yeah that's a 'spensive little piece - but on the bright side, I've never heard of a 931 decel valve going bad. I once suspected mine might be bad, looked up the price and decided based on price alone that there was nothing wrong with the one I already had. -And the problem did turn out to be something else, so my decel valve was, and still is good.
A bad vacuum line is a distinct possibility - especially a bad vac control line to the decel valve - that would both leave the decel valve non-functional, and be letting in air which would lean the mix..
Replace all vac lines, and check the rubber boots and o-rings in the intake path before wasting too much time thinking about where the problem is.  _________________ "..it's made in Germany. You know the Germans always make good stuff."
Aussie931
Posted: Tue Mar 18, 2008 4:39 pm Post subject: |
I agree with smoothie. The vacuum limiter is unlikely to be suspect. I had the same issue with my 931 and it was due to the mixture being too lean. I replaced all of the vacuum lines - this helped a little however it didn't get sorted completely until I adjusted the mixture. In regards to the decel valve/vacuum limiter, I have removed mine and it has made very little difference to the car's performance. From what I understand, it is fitted more for emission control as it leans off what would otherwise be a rich mixture on decel after heavy acceleration. _________________ 1979 Series 1 924 turbo |
