Reverse gear synchro??
71vdubturbo
PostPosted: Mon Mar 17, 2008 6:20 am    Post subject: Reverse gear synchro?? Reply with quote
My 4 speed the other day wouldn't go into reverse without a terrible grind. I had driven it for about an hour so it was nice and warmed up.
Is there a reverse gear synchro?
Would too light of gear oil cause this? I used what haynes recommended, 80w90.
Do I just need another transmission? (This would be what my economic stimulus tax refund would go to.)
1977 Porsche 924 - going away...
2001 Audi S4 - 2.7T, Tip
PostPosted: Mon Mar 17, 2008 6:33 am    Post subject: Reply with quote
How's the shift lever? They can wear, develop a lot of play and make it hard to get into reverse. Also try shifting into other gears - 1, 2, before going for reverse - this eliminates any possibility for a little grind when going for R.
71vdubturbo
PostPosted: Mon Mar 17, 2008 7:40 am    Post subject: Reply with quote
The original stud on the shift lever broke. I welded a bolt onto it. It does need a new shift lever but that will happen when the funds come in.
I tried the shift-to-1st-or-2nd trick but it still didn't help.
PostPosted: Mon Mar 17, 2008 7:46 am    Post subject: Reply with quote
Some 5-speeds have a synchro, but I think not all... and I'd be a little surprised if the 4-speeds do.
71vdubturbo
PostPosted: Mon Mar 17, 2008 8:34 am    Post subject: Reply with quote
That being said, I guess my transmission is just old and in need of replacement. I've been on the lookout for a audi-style 5 speed from a 924. Haven't found anything yet but I guess the search is still on. Thanks guys.
PostPosted: Mon Mar 17, 2008 10:48 am    Post subject: Reply with quote
Might your clutch be out of adjustment?
71vdubturbo
PostPosted: Mon Mar 17, 2008 11:39 am    Post subject: Reply with quote
Well, I thought that at first. I just changed the clutch and pressure plate about a month ago (roughly 200 miles). I adjusted everything when I changed it.
PostPosted: Mon Mar 17, 2008 1:07 pm    Post subject: Reply with quote
Time to check it again, non hydraulic operated clutches usually need adjusted a few hundred miles after replacement.
71vdubturbo
PostPosted: Mon Mar 17, 2008 1:23 pm    Post subject: Reply with quote
Cool. I'll have to check it in the morning.
!tom
PostPosted: Tue Mar 18, 2008 7:37 am    Post subject: Reply with quote
Pilot bearing?
78 924 NA
5-lug
StienbargerR
PostPosted: Tue Mar 18, 2008 11:51 am    Post subject: Reply with quote
are you at a dead stop when you shift into reverse? Mine grinds if I'm rolling a bit.
Ryan
1978 924 NA
71vdubturbo
PostPosted: Tue Mar 18, 2008 2:20 pm    Post subject: Reply with quote
I changed the pilot bearing when I did the clutch.
I'm at a dead stop when I try to shift. When it's cold it goes into reverse fine. It's when it's warm when I get problems.[/quote]
