Car is back, some odd questions here and there.
sparky
PostPosted: Fri Mar 14, 2008 11:28 pm    Post subject: Car is back, some odd questions here and there. Reply with quote
Hey Guys,
I got my car back yesterday and have been pretty busy this past week or two, and have only been on the board looking at the odd posts.
Unfortunately I am not happy with the work the guy did setting the mixtures and timing, I still beleive the mixture is out and he did not bother touching it. When I asked him what the gas analyzer results were he said: ohhh 3.7. I told him it is meant to be around the 1 mark. he quickly replied it is 3.7 cold and 1 when warm.
Does this make any sense or sound correct? Personally I do not beleive it is set right. There are the odd misses at low revs. I will give the whole air and fuel system a once over soon.
When it is revved up it does this pretty smoothly but there is a high pitched metallic vibration sound coming from the engine at around 4k. What should I look for? Do these engine usually rev quickly all the way to the 6/7k mark or go to about 4k quickly and then the last bit?
First on the list is to get the interior 100% so that chapter is closed. I will probably leave the speakers to the end. The head unit is in but I need to make a neat looking spacer as it has to sit out about 1" so the screen does not hit the heater control knobs and cig lighter.
The next slight problem is with the remote start. I have not looked into the wiring of it yet, but the system knows that the car has actually started from the engine revs. It stops cranking when they touch 1k. On modern cars this is not a problem as when it starts it fires up to above 1k and then settles at the normal place. Since when this car starts it goes to 500rpm and settles at 800rpm the system does not think the car has started and continues to crank. Anyone got a way around this? I will also check the manual tonight and see if there is anything to adjust this.
I got a set of stock power windows for it and the window sliders and motors are installed. The passanger window works fine, but when the drivers window motor is activated the door metal which the motor is attached to flexes a tiny bit and it does not go up smoothly. Anyone seen this before?
If time allows, I will try and finish the interior within 2 weeks so that will only leave the last bit of fine tuning for the engine, installation of the front clip and lights along with the mirrors and the suspension. At that stage I can get the car on the road but it will need a re-spray to be complete.
Its very close now and the first job on the list is to get the split rear seats in and rear seatbelts. Although the car did not come with rear belts fitted, it is law over here to install them anyway. I got the shoulder belts so there wont be any parts poking who ever is squashed back there's butt.
Im sure there are more questions, but this should cover a bunch of them for now.
All help and advice is appreciated!
Many thanks again!
SparkY
When the checkered flag drops... The Bull$hit Stops
1976 Euro 924 (The 945) - Full 951 Brakes/Suspension
1998 Boxster with goodies
2002 3.0 Xtype 4wd sport
PostPosted: Fri Mar 14, 2008 11:47 pm    Post subject: Reply with quote
They definitely should pull strong all the way to redline and past, when in proper tune. Sounds like your mech did indeed try to bluff his way through that. Good news is it's easy to tweak it yourself! I'd try richening it up, but another way (which I often use on the racecar) is when it's warmed up fully, first lean, then richen it, until it starts to stumble, making note of where those points are. Then set the mixture to dead nuts in the middle, plus a little, like 5 degrees, to the rich side. That should run pretty well.
Doesn't hurt to make sure the timing's set properly before this.
As for the starter - yes, I'd definitely look into the programming of the starting system itself.
sparky
PostPosted: Sat Mar 15, 2008 2:15 am    Post subject: Reply with quote
Thanks mate,
I will give that a shot after I check there are no leaks anywhere.
From that I recall CCW=Lean CW=Rich?
I will let you know how that goes this weekend
An update on the engine noise, it sounds like metal resonating under the valve cover. I have not pulled this off yet, but can anyone tell me what this could be.
Last thing that just started happening is the starter motor only works 1/2 the time. The other times it just click, I will inspect all the wiring to it, but ASAIK it was all in great shape.
Thanks again and keep the comments coming
SparkY
PostPosted: Sat Mar 15, 2008 2:43 am    Post subject: Reply with quote
Yeah, CCW is leaner, CW is richer...
Sounds like the startre or solenoid is dying...
PostPosted: Sat Mar 15, 2008 3:04 am    Post subject: Reply with quote
Hello sparky,
i just checked my german "Prüfbescheinigung" (report) that is for emissions.
It says engine temp. has to be above 80 Deg.Celsius, engine idle between 850 and 1050 and % volume should be between 0.00 and 2.00.
So your one should be fine but 3 is out......
all readings for a 1977 N/A without catalytic converter.
Nobbi :
sparky
PostPosted: Sat Mar 15, 2008 6:29 am    Post subject: Reply with quote
Cheers for the info nobbi and also 924RACR, I will get onto doing it by ear first and see how that goes
It does sound like the solenoid is dying, but I will also check the wiring to the starter motor, maybe it is not always getting good current?
Thanks again guys, any suggestions on the other problems?
SparkY
PostPosted: Sat Mar 15, 2008 8:08 am    Post subject: Reply with quote
Tell your starting system you have 8 cylinders.
sparky
PostPosted: Sat Mar 15, 2008 11:49 am    Post subject: Reply with quote
Thanks Rasta, I tried speaking to it earlier today, but just beeped at me. I presume that it was blanking out the obscene words. I have not RTFM yet to be honest
I am hoping that the starter will just be a silly wiring problem, but I am guessing it is more likely the solenoid like 924RACR suggested
I wish I had more time right now so I could get all the small silly jobs out the way in 1 go.. but right now I have no time
I tried recording the exhaust music but it did not come out very well. I will get another recording device near it soon so I can post the lovely sound.
The main things that I will address before getting the whole interior in place is the resonating sound from under the valve cover, the starter motor and finding out why it does not rev all the way up to the redline. It is possible it just needs a good run, and to be honest, since I have owned the car it has only gone on one run around the block.
I will try and obtain a permit to take it on a longer run sometime as the license plates are garaged and I cannot get them back until it passes a VRT/MOT.
How long a run should the car need to really clean out the engine?
SparkY
!tom
PostPosted: Wed Mar 19, 2008 3:31 am    Post subject: Reply with quote
That's actually a great idea in all seriousness -- I'd expect somewhere in your system, there is a way of selecting how many cylinders your engine has so that it can read the signal from the coil properly.
If you configure your system for an 8 cylinder car, it will "think" your 4 cylinder engine is running twice as fast as it really is. This way a pre-programmed in cutoff of 1000 RPM will result in it cutting off at 500 RPM for your car, which sounds about right.
This is because the coil fires twice per engine revolution on a 4 cylinder car, and 4 times per revolution on an 8 cylinder car.
78 924 NA
5-lug
PostPosted: Wed Mar 19, 2008 4:52 am    Post subject: Reply with quote
!tom wrote:
... the coil fires twice per engine revolution on a 4 cylinder car...
Three times: once at the top, once at the bottom and once at the top again!
