Posted: Mon Feb 25, 2008 6:02 pm Post subject: |
| Rich H wrote: | | Will an normal petrol injector work with vapourised LPG or is that silly? |
I think the idea is not to let the LPG vapourise until it's been through the injectors. _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
Rich H
Posted: Mon Feb 25, 2008 6:06 pm Post subject: |
I thought that the vaporiser did that before distribution to the injectors?
I don't know for sure though.... _________________ 1994 Lotus Esprit S4 - Work in progress...
Martijnus
Posted: Mon Feb 25, 2008 8:21 pm Post subject: |
| Rich H wrote: | | I'm interested again as I'm looking at ITBs which have injector ports but my fuel rail is bolted to the head and using the original injector ports, so a second set of injectors could be fitted easily. Will an normal petrol injector work with vapourised LPG or is that silly? |
in my situation it's the other way around... my gasoline injectors are on the ITB's and I've got the holes from the stock injectors in the head.
I was using these stock holes for vacuum...but now I'm going to use it for LPG injectors.
I'm not sure what injectors can be used for LPG... you can vaporize the lpg, which is the old system, or inject it in liquid form which is lpi.
I don't know what the temperature and pressure will be compared to gasoline but a friend of mine mentioned a "dry gas injector"... which he thought could be used in combination with megasquirt. _________________ "Rule: Turbo's make torque, and torque makes fun." (C. Bell)
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
Rich H
Posted: Mon Feb 25, 2008 8:33 pm Post subject: |
Never thought of that! Injector holes for Vac takeoff, its obvious now
Cheers Martijnus!
If its Liquid when you inject it then I don't see why normal injectors won't work just fine, I assume that the spray will atomise it and the hot intale tract will vaporise it, dunno about high revs though, and also you will need to sort out the change over form LPG to gas and back, could be tricky to manage or would you just have a snap change over?
R _________________ 1994 Lotus Esprit S4 - Work in progress...
Martijnus
Posted: Mon Feb 25, 2008 9:15 pm Post subject: |
| Rich H wrote: | Never thought of that! Injector holes for Vac takeoff, its obvious now
Cheers Martijnus!
R |
that's what I thought too but I don't know if LPG has some strange temperature which damages the injector...or that it runs on extreme pressure or whatever...
If it's possible to use gasoline injectors the possibilities are endless
btw, that vacuum stuff was stolen from this board I havent got anything yet, but I'm planning to use it for vacuum.
You get your MAP vacuum from the manifold?
Have you thought about your vacuum supply when you get ITB's? that was my problem... My vacuum was gone.
You will have to build some sort of buffer which smoothes out the vacuum pulses if you get vacuum from a runner (or injector hole...)
http://www.924board.org/viewtopic.php?p=184288#184288 _________________ "Rule: Turbo's make torque, and torque makes fun." (C. Bell)
drwal
Joined: 24 Feb 2008 Posts: 29 Location: Opole - Poland
Posted: Mon Feb 25, 2008 10:39 pm Post subject: |
firstly: hello becouse i am new in here and i am from poland, so sorry for my bad englihs...
secondly:
some of my friens have LPG in their p924. it works, but it albo depends of generation of the lpg system.
the most problem is too regulate it with k-jetronic. also the temperature of burning gas is higher, so it is not good for the engines head.
we can feel the loss of power on gas.
Some of them tries too install a BLOS system and it is a king of little carbourater for lpg, mountin on the pipe between k-jet and the air intake system(? i dont know the technical name of it, the aluminium which give us the balance of air with a porsche sign ). And using a blos, the power is a little lower as on petrol.
but i dont think its is good way to lpg system in 924.
Maybe if sbd does 10k km per month with this car
also on gas there are some gas blows that can destruct some part of the k-jet.
maybe next time i will take a dictonary and tell a little more, becouse i now a lot of that system, and if it works good, but i hevent got in my mind technical words  |
Martijnus
Posted: Tue Feb 26, 2008 2:19 am Post subject: |
thanks for sharing the information!
The K-jet is already gone in my car and also at Rich-h's car. so that's no problem anymore
Since i've raised my comperssion ratio, my engine temperature will be a little bit higher, so an oil cooler will be installed anyway.
I also want to cut the valve seats a little different to supply the valves with enough surface to cool down.
monitoring oil temperature and so on will keep everything safe.
and al the trouble you mention is the reason I don't want to use the non-liquid injection. _________________ "Rule: Turbo's make torque, and torque makes fun." (C. Bell)
Rich H
Posted: Tue Feb 26, 2008 3:43 am Post subject: |
For the MAP I was going to link all the runners with a vacuum line and take a tapping from there. TO damp it out I haev seen a small fuel filter used in line with the map sender which causes enough of a restriction to damp out the changes. Thats what I will try anyway.
I nned a vacuum line for the brake servo anyway, I could combine the 2 I suppose. _________________ 1994 Lotus Esprit S4 - Work in progress...
cadetboy2
Joined: 30 Oct 2007 Posts: 5 Location: Worcestershire England
Posted: Tue Feb 26, 2008 4:54 am Post subject: Porsche & LPG |
Perhaps somebody should talk to this lady.
Ebay item 290207369107
Cheers Bob |
Rich H
Posted: Tue Feb 26, 2008 5:04 am Post subject: |
That is a big tank!
drwal
Posted: Tue Feb 26, 2008 5:15 am Post subject: |
| lot of people mounts lpg tank as/for the emergency wheel, and the 5th wheel goes to bag. |
Martijnus
Posted: Tue Feb 26, 2008 8:31 am Post subject: |
yeah but those space saving porsche spares caused a limited space... and for a few litres it's not worth it.
I guess 30 lit is the max.
anyway...my plans have slightly changed. I'm not converting to LPI, because it's expensive, parts are expensive too and the advantage over gas-state isn't that much imho.
So I found out you can inject it in gas-state too Don't know yet what the injectors will cost but I'll find out soon.
It uses less lines, less parts and has less things to fail compared with LPI.
The pumps in the tank cease quite often, i've been told, and that means replacing the whole tank. $ 600
With injectors the same thing... more than 200$ a piece.
Gasstate petrol doesn't need a pump... _________________ "Rule: Turbo's make torque, and torque makes fun." (C. Bell)
Martijnus
Posted: Fri Feb 29, 2008 3:08 am Post subject: |
wow...
Some shop close to my location has a set of 4 (dry gas) injectors and a evaporator... so, that's 50% of the parts that I need...the rest is small stuff like hoses, valves and lines... and a tank of course but I'll lend one from someone to pass the tests and then buy a cheap non-approved one. (to today's standards...it's not illegal)
He wants 185 eur for the 4 injectors and evaporator... that's cheap! that means I can be done for under 300 eur!
so...thát means I've got my money back after 3000km's or something like that... that's just after the break-in period
edit: the advantage is that I'll be using megasquirt, which doesn't give extra costs for a gas computer. _________________ "Rule: Turbo's make torque, and torque makes fun." (C. Bell)
Rich H
Posted: Fri Feb 29, 2008 8:56 am Post subject: |
Nice work!  _________________ 1994 Lotus Esprit S4 - Work in progress...
Posted: Fri Feb 29, 2008 9:25 pm Post subject: |
martijnus,
sounds great, i hope it will work and i am able to take a look at your car when we meet at the `Ring`.
Nobbi  _________________ NA 924 - april/1977- 4-speed-audi gearbox.
