Did Something Stupid and Need Help
dpw928
PostPosted: Thu Feb 14, 2008 12:13 am    Post subject: Did Something Stupid and Need Help Reply with quote
The connector cover for my DITC is missing and the wires/pins are exposed. Last night when checking the connections, two wires came loose. Upon reconnection (obviously at the wrong pin) the engine will not start. I've checked the WSM but it doesn't give the colors code of the wires nor the pin numbers. Would anyone have a diagram and color code list of the connections?
Thanks
Dennis
81 931 5 sp
78 928 5 sp Silver
78 928 AT Euro Black
PostPosted: Thu Feb 14, 2008 2:38 am    Post subject: Reply with quote
T12 = br & br/re
T11 = bk
T9 = br/bk
T7 = br/wt
T5 = wt/bl
T3 = gr/wt
I was confused by T13, T14 & T15, because I don't fully understand wiring diagrams.
There are two wires from the pulse generator, (bk and ye) that appear to go to T13 and T14, but they don't get all the way there. There is a fine dotted line, not labeled as a wire, that goes from a third terminal on the pulse generator to T15. the bk and ye wires terminate at this dotted line at both ends (at the DITC and at the pulse generator). Sorry, I don't know what this means.
dpw928
PostPosted: Thu Feb 14, 2008 2:46 am    Post subject: Reply with quote
Thanks. This should get it. IIRC the dotted line is a shielded ground line. Was this in the WSM?
Dennis
81 931 5 sp
78 928 5 sp Silver
PostPosted: Thu Feb 14, 2008 2:48 am    Post subject: Reply with quote
Ja
dpw928
PostPosted: Thu Feb 14, 2008 2:57 am    Post subject: Reply with quote
I checked the supplement on the 81 turbo but didn't see it. Was it in another area?
Thanks,
Dennis
81 931 5 sp
78 928 5 sp Silver
PostPosted: Thu Feb 14, 2008 2:58 am    Post subject: Reply with quote
My turbo volume has additional wiring diagrams in the back. This was in Part I.
dpw928
PostPosted: Thu Feb 14, 2008 3:30 am    Post subject: Reply with quote
I'll check mine tonight.
Thanks,
Dennis
81 931 5 sp
78 928 5 sp Silver
dpw928
PostPosted: Tue Feb 19, 2008 1:52 am    Post subject: Reply with quote
Reconnected the plugs yesterday (correctly) and it started and ran great. It also solved a high idle problem I was having.
Thanks,
Dennis
81 931 5 sp
78 928 5 sp Silver
PostPosted: Wed Aug 15, 2012 6:42 pm    Post subject: Reply with quote
What about the green/red&white wires?
PostPosted: Thu Aug 16, 2012 4:19 am    Post subject: Reply with quote
i cleaned the ditc connector before i leave to a 4000km holiday and i lost the order of the wires.
i used the info above and all is well...the car runs great.
BUT.....additional to the above mentioned wires, i do have another two wires that are bridged and connected to terminal 2..or 4...cant remember exactly..but the main question is...what are those wires for? where should they be connected? should they be connected?
