Starting problems
KOTA5682
PostPosted: Sat Feb 09, 2008 9:47 pm    Post subject: Starting problems Reply with quote
Just bought my first Porsche, a 924s. I am having intermittant starting problems. I have replaced the ignition switch and DME relay. I have checked the resistance of the speed and reference mark sensors as well as the coil. I am going to hook up a light to verify power to the coil every time the ignition is on. Sometimes it will start and then stop after 5 seconds hot or cold, sometimes not.Then sometimes if I just give it some time it will start. Should I be looking at the fuel system?
PostPosted: Sun Feb 10, 2008 1:37 am    Post subject: Reply with quote
Welcome to the board!
Take a look here:
http://www.clarks-garage.com/shop-manual/eng-15.htm
PostPosted: Sun Feb 10, 2008 1:38 am    Post subject: Reply with quote
BTW is the car an 87 that's white with 17" 993 wheels?
PostPosted: Sun Feb 10, 2008 11:53 am    Post subject: Reply with quote
The last time that car had that problem, the issue was bad grounds on the engine block underneath the heater valve.
Neil924
PostPosted: Sun Feb 10, 2008 12:54 pm    Post subject: Reply with quote
I think it's a possibility that Paul may know something about your car, it's only a guess though.
PostPosted: Sun Feb 10, 2008 1:05 pm    Post subject: Reply with quote
I believe it's my old 924S that I should have never sold a couple of years ago.
PostPosted: Sun Feb 10, 2008 1:11 pm    Post subject: Reply with quote
He'll respond in a few minutes now - after he gets the car pulled into the garage, and has the door closed and locked.
PostPosted: Sun Feb 10, 2008 1:17 pm    Post subject: Reply with quote
I almost did a "Neil" a week or two ago, but then it was suddenly sold to someone who showed up with a trailer and took it to his house.
I'm guessing it was KOTA5682.
Neil924
PostPosted: Sun Feb 10, 2008 1:58 pm    Post subject: Reply with quote
That bastard!
Neil924
That smart bastard!
