2Fast
Joined: 09 Dec 2007 Posts: 459 Location: Klamath Falls, OR
Posted: Thu Feb 07, 2008 7:35 am Post subject: Where do these wires go? (large pictures) |
I have two loose wires lying around in my car and they are driving me crazy. If you guys could help me find where they go, I would really appreciate it. (man, my engine is a mess.... )
Heres numero uno...
It is the red plugin, I have no idea where it goes, It doesnt go to the CSV or the round thing that has a black hose connected (hose starts above cold start valve and leads to the round thing) to it.
No. 2
This red wire goes from the fuel pump, and ends up here...
I have no idea where the red wire goes to...maybe the fuse box?
Those are the two, and any help would be appreciated. _________________ =====>Alex<=====
1979 Porsche 924 NA 5spd
1979 Parts Porshce 924 NA 5spd
!tom
Posted: Thu Feb 07, 2008 7:48 am Post subject: |
Number 2 is easy -- that's a hack by the previous owner to bypass the fuel pump relay.
That wire does not belong in your car.
Number 1 is interesting. To me it looks like your AAV is not connected properly, and I was thinking the connector might belong to the AAV. _________________ 78 924 NA
5-lug |
2Fast
Posted: Thu Feb 07, 2008 7:51 am Post subject: |
| !tom wrote: | Number 2 is easy -- that's a hack by the previous owner to bypass the fuel pump relay.
Number 1 is interesting. To me it looks like your AAV is not connected properly, and I was thinking the connector might belong to the AAV. | Should I remove number 2? _________________ =====>Alex<=====
1979 Parts Porshce 924 NA 5spd |
joecitizennn
Posted: Thu Feb 07, 2008 7:59 am Post subject: |
| It was probably bypassed because of a bad relay. So your car might nut run till you fix it right. |
2Fast
Posted: Thu Feb 07, 2008 8:03 am Post subject: |
| joecitizennn wrote: | | It was probably bypassed because of a bad relay. So your car might nut run till you fix it right. | Well, that would explain why it wont run. _________________ =====>Alex<=====
Posted: Thu Feb 07, 2008 8:17 am Post subject: |
There is 3 plugs in the motor area.
The AAV, WUR and CSV.
All different colors. Blue, Brown/red and Black IIRC.
Blue is the CSV, cant remember the other 2 which is what. _________________ Porsche 924 1984 (UK import) NA
2Fast
Posted: Thu Feb 07, 2008 8:18 am Post subject: |
| Ozzie wrote: | There is 3 plugs in the motor area.
Blue is the CSV, cant remember the other 2 which is what. | whats the AAV? Im not good with abreveations. _________________ =====>Alex<=====
Posted: Thu Feb 07, 2008 8:22 am Post subject: |
You should try my job with the Dept of Defense.
Auxilliary air valve. its the round thing with the hose on one end going to the intake manifold.
Is the air intake boots off the throttle body for a reason? _________________ Porsche 924 1984 (UK import) NA
2Fast
Posted: Thu Feb 07, 2008 8:25 am Post subject: |
| Ozzie wrote: | You should try my job with the Dept of Defense.
Is the air intake boots off the throttle body for a reason? | lol, i have them off because it is easier to reach the injectors that way . So, the plug doesnt go to the CSV or the AAV, so i guess my question is, what does WUR stand for. _________________ =====>Alex<=====
RC
Posted: Thu Feb 07, 2008 8:59 am Post subject: |
According to my perception of color that connector is brown. This corresponds to the thermo time switch mounted at the bottom of the coolant flange at the rear of the head.
The red wire on the pump is a botch job. IIRC stock is green/black 4.0 mm2. Runs from the pump, along the LH side of the car and resurfaces near the fuse panel and terminates at an insulated spade connector that leads to the FP relay. Would really suggest trying to return this to stock and repair any faulty wiring or relay.
Roger |
2Fast
Posted: Thu Feb 07, 2008 9:01 am Post subject: |
| RC wrote: | According to my perception of color that connector is brown. This corresponds to the thermo time switch mounted at the bottom of the coolant flange at the rear of the head.
Roger | Im trying to restore it, just some idiot thought he was a mechanic and screwed a lot of stuff up. _________________ =====>Alex<=====
Posted: Thu Feb 07, 2008 12:47 pm Post subject: |
Thought he was a electrician too.
Removed the Thermo time switch connection and put in a CSV bypass and fuel pump relay bypass.
Chrissake I hate people like that. Why dont they fix the fault instead of making things worse. _________________ Porsche 924 1984 (UK import) NA
sparky
Posted: Thu Feb 07, 2008 1:33 pm Post subject: |
Jumping in late on this one.. but yep thats definately the thermo time switch connector.
It plugs in at the back of the engine below the oil pressure sendor. Not too easy to see, but pretty simple to hook up..
Looks like you will have to test the cold start system 2Fast. Pretty easy job to do.. Btw Ozzie is my electonics teacher  _________________ When the checkered flag drops... The Bull$hit Stops
1976 Euro 924 (The 945) - Full 951 Brakes/Suspension
1998 Boxster with goodies
2002 3.0 Xtype 4wd sport |
StienbargerR
Posted: Thu Feb 07, 2008 2:05 pm Post subject: |
what about the temp sender? in the back of the engine.
Ryan _________________ 1978 924 NA
Posted: Thu Feb 07, 2008 3:18 pm Post subject: |
Never seen the one on the thermo time switch so forgot about it.
CSV is Blue
WUR is grey
AAV is black
TTS is red _________________ Porsche 924 1984 (UK import) NA
