Zermatt924SUK
Posted: Tue Jan 22, 2008 3:24 am Post subject: Anyone Removed their front wings? |
| Had a Bit of a Bump...one Needs Changing as it's damage...I'm changing the Other as the Rust has started eating it! |
Posted: Tue Jan 22, 2008 5:15 am Post subject: |
The front fenders are bolted on and are very flimsy once removed.
Remove the obvious bolts under the hood, then the one by the headlight, and 2 bolts to the front spoiler. Disconnect the side marker wiring. Remove 3 bolts inside the wheel well behind the charcoal canister on a US car. (bolts the back of the fender to the door jam.) _________________ White 87 924S "Ghost"
Rich H
Posted: Tue Jan 22, 2008 5:28 am Post subject: |
I got all the bolts out but gave up as my wing was glued on with something like no-nails. Don't you just love POBs....  _________________ 1994 Lotus Esprit S4 - Work in progress...
Posted: Tue Jan 22, 2008 5:29 am Post subject: |
12 pics starting here of approximately what you should find with the fenders removed -
<click>
The 3 inside bolts holding the rear vertical surface of the fender to the door jamb area will probably be well-covered with undercoating (somewhat tough to find, then require scraping off to get a wrench on them).
-And as I recall, I think I pulled out the rubber piece at the front-bottom of the headlight to get at that single front bolt. _________________ "..it's made in Germany. You know the Germans always make good stuff."
Posted: Tue Jan 22, 2008 5:30 am Post subject: |
| Rich H wrote: | I got all the bolts out but gave up as my wing was glued on with something like no-nails. Don't you just love POBs....  |
Yes - you also have to go in with a couple of putty knives to seperate the top edge of the fender after those bolts are removed. _________________ "..it's made in Germany. You know the Germans always make good stuff."
Zermatt924SUK
Posted: Tue Jan 22, 2008 5:31 am Post subject: |
| Thank You All! |
Posted: Tue Jan 22, 2008 5:45 am Post subject: |
Smoothie's pictures reminded my failing memory that there is also a bolt on the very bottom rear of the fender. _________________ White 87 924S "Ghost"
924guy
Posted: Wed Jan 23, 2008 12:23 am Post subject: |
i used a heat gun to soften the coating, helped allot... just dont breath in the fumes, it cant be healthy.... ive got a respirator just for things like this. _________________ Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha |
