Diff question
Goto page Previous  1, 2
Fill
PostPosted: Tue Jan 15, 2008 6:35 am    Post subject: Reply with quote
will be looking forward to, m8
joecitizennn
PostPosted: Tue Jan 15, 2008 9:06 am    Post subject: Reply with quote
Rich H
PostPosted: Tue Jan 15, 2008 9:10 am    Post subject: Reply with quote
hmm shiney...
Fill
PostPosted: Tue Jan 15, 2008 8:18 pm    Post subject: Reply with quote
joecitizennn wrote:
as i can see it is easy to remove differential
joecitizennn
PostPosted: Wed Jan 16, 2008 11:49 am    Post subject: Reply with quote
easy removal of the diff,, well yes but you will have to split the case to get the pinion and the input shaft out of the way. Then the ring/diff assembly can be lifted out.
Rich H
PostPosted: Wed Jan 16, 2008 7:59 pm    Post subject: Reply with quote
Are the output bearings a standard size? Will it all need re-shimming and so on if I change the rollers? I don't fancy trying to change the races as they are press fit in a hot cast... 180 deg c!!
Page 2 of 2
