peebles24
Joined: 27 Jul 2007 Posts: 43 Location: Terre Haute, IN
Posted: Sun Jan 13, 2008 3:32 am Post subject: windows fog up |
I am having problems with my windows fogging up real bad. Over night they will frost on the inside. Open the car in the morning and I have to wipe down the windows and the headliner because of all the dew. I have never seen a car fog (dew) up like this inside.
Has anyone ever had this problem and is there some cure.
Thank You,
Chad P. _________________ 1981 924 Weissach, progressive rate coils, Dansk Polished S/S exhaust, free flow Cat, K&N filter
1991 Toyota FJ80 |
Rich H
Posted: Sun Jan 13, 2008 3:50 am Post subject: |
My car does that, check that the rear hatch seal is good and you have no leaks. There are rubber bungs all over the chassis that will be letting in the moist air. Chances are you will just have to put up with it as you'll never get the car properly dry ever again. If you have a friendly bodyshop nearby you could ask them to bake it for you. Used to do that when I worked in a paintshop, dries them out a treat. _________________ 1994 Lotus Esprit S4 - Work in progress...
2Fast
Joined: 09 Dec 2007 Posts: 459 Location: Klamath Falls, OR
Posted: Sun Jan 13, 2008 4:54 am Post subject: Re: windows fog up |
| peebles24 wrote: | I am having problems with my windows fogging up real bad. Over night they will frost on the inside. Open the car in the morning and I have to wipe down the windows and the headliner because of all the dew. I have never seen a car fog (dew) up like this inside.
Thank You,
Chad P. | I would look at replacing all of the seals, door seals, hatch seals, sunroof seal, and if it doesnt get fixed, look at replacing the window seals. _________________ =====>Alex<=====
1979 Porsche 924 NA 5spd
1979 Parts Porshce 924 NA 5spd |
Posted: Sun Jan 13, 2008 6:53 am Post subject: |
Take out your wet washing supplies,dry your floor carpet, check passenger side for water,maybe your heating system has a leak.Drive with vents open.Check rubber seals in the chassis,round black ones in the trunk area.
Nobbi |
peebles24
Posted: Sun Jan 13, 2008 11:47 am Post subject: |
I know my 91 land cruiser has at least one bad door seal and it doesn't do this. My passenger side carpet is wet but it's behind the front seat. What would a paint shop charge me to bake it? _________________ 1981 924 Weissach, progressive rate coils, Dansk Polished S/S exhaust, free flow Cat, K&N filter
1991 Toyota FJ80 |
Posted: Sun Jan 13, 2008 12:47 pm Post subject: |
Yessir, it means you have too much moisture in the car. Obviously find out where it's coming in and try to fix that, but in the mean time, you don't have to live with the fogged/frosted on the inside windows situation. The fix for that is easy - just leave the windows opened about 1/4", or more if you can or dare.
The problem is, when it's cold out, you drive around with the heat on, get the interior nice and warm, then park and shut the windows - now the warm interior air can and does hold moisture...eventually the cold outside air cools the windows, then moisture from the interior air condenses on the insides of the windows. If below freezing, it turns to frost. By simply leaving the windows opened a bit, colder, drier air is allowed in, and warm moist air is let out, until temperature and humidity equalize between interior-exterior and wholla - no condensation, and no frost. _________________ "..it's made in Germany. You know the Germans always make good stuff."
Posted: Sun Jan 13, 2008 1:31 pm Post subject: |
Is this happening after a "date" with your gf? _________________ White 87 924S "Ghost"
peebles24
Posted: Mon Jan 14, 2008 1:28 am Post subject: |
| Paul wrote: | | Is this happening after a "date" with your gf? |
I wish! I'm married no steamy stuff for me. Leaving the window cracked makes good sense I just have to watch the weather. _________________ 1981 924 Weissach, progressive rate coils, Dansk Polished S/S exhaust, free flow Cat, K&N filter
1991 Toyota FJ80 |
PORSCHEV
Posted: Mon Jan 14, 2008 1:42 am Post subject: |
| peebles24 wrote: | | My passenger side carpet is wet but it's behind the front seat. What would a paint shop charge me to bake it? |
The steamy windows is the result of the water trying to evaporate from your wet carpet. Eliminate the leak..let the car dry out..problem gone! _________________ 1976 924
1978-#53 "D" track racer. |
Posted: Mon Jan 14, 2008 2:06 am Post subject: |
| peebles24 wrote: | | I'm married no steamy stuff for me. |
That ain't right. _________________ Toofah King Bad
tuurbo
Joined: 08 Aug 2007 Posts: 1446 Location: East Windsor, New Jersey
Posted: Mon Jan 14, 2008 3:53 am Post subject: |
Drains:
If you have a sunroof there are holes you can use compressed air to blow out any grunge and let the area drain.
Under your rear light assembly there is a light colored hose that goes down into behind the wheel well - blow that out too - also make sure the rubber hose goes into a rubber grommet thing and lets the water go outside the car. I've seen that area fill with water when the hose isn't plumbing outside. _________________ 1980 924 turbo, MSD, Meth. Inj, otherwise stock. |
peebles24
Posted: Tue Jan 15, 2008 6:49 pm Post subject: |
| Rasta Monsta wrote: | | peebles24 wrote: | | I'm married no steamy stuff for me. |
That ain't right. |
Not right but very true, sucks that much I can guarantee. I do really meant I don't. I'll check those drains, thank you. _________________ 1981 924 Weissach, progressive rate coils, Dansk Polished S/S exhaust, free flow Cat, K&N filter
1991 Toyota FJ80 |
