Fuel gauge not reading full? Try this!
Rich H
PostPosted: Sun Jan 06, 2008 9:40 pm    Post subject: Fuel gauge not reading full? Try this! Reply with quote
If your gauge is not reading full even after remortguaging the house and filling the tank (Fuel is now over £1 a liter ~$8 a gallon) try this:
Pull up the sender cover in the boot (Big rubber bung) and there are 3 spade connectors.
Pull each one off in turn and clean them with a fiberglass pencil (If you have one) or a bit of fine Wet and Dry abrasive paper.
Slap some of the girlfriend's vaseline on each.
squeeze the spade connector with pliers and refit.
Voila, full acknoledgement of your hard won expensive fuel load.
If this doesn't work then the advanced version:
Pop out the gauge unit from the dash (It just pushes out, push harder!) and take it to bits.
3 screws round the outside and 2 on the inner plate, not the nuts, thats next.
The whole lot comes to bits then (Don't worry its not that complicated)
Once apart undo the nuts on the back and the gauge units will pull off the board (I had to gently lever them off)
Clean the pins that they plug onto with fine wet and dry and vaseline them again.
Reassemble.
Clean and vaseline the pins on the back of the board too for good measure.
Jobs a carrot
Rich
PostPosted: Mon Jan 07, 2008 3:50 am    Post subject: Reply with quote
Nice how-to, but my wife uses dielectric grease.
Rich H
PostPosted: Mon Jan 07, 2008 4:57 am    Post subject: Reply with quote
tuurbo
PostPosted: Mon Jan 07, 2008 5:01 am    Post subject: Reply with quote
There are just too many reply possibilities here...lol
1980 924 turbo, MSD, Meth. Inj, otherwise stock.
PostPosted: Mon Jan 07, 2008 5:56 am    Post subject: Reply with quote
Probably has a short.
Vince Ponz
PostPosted: Mon Jan 07, 2008 7:54 am    Post subject: Reply with quote
You can try that but I warn you that the skinny three or so lines are very thin and they stretch.Ask me how I know.
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock
PostPosted: Tue Jan 08, 2008 3:52 am    Post subject: Reply with quote
Yeah, but what about the fuel guage?
PostPosted: Tue Jan 08, 2008 4:19 am    Post subject: Reply with quote
It looks to me like the original Howto is describing cleaning the connections on the outside of the tank, rather than the actual fuel sender components inside the tank.
78 924 NA
5-lug
Rich H
PostPosted: Tue Jan 08, 2008 5:12 am    Post subject: Reply with quote
Definatly the outside connectors. I didin't open the tank.
Vince Ponz
PostPosted: Tue Jan 08, 2008 8:16 am    Post subject: Reply with quote
You can open it and pour some liquid cleaner in but just open it enough to pour it in. The wires are VERY thin. They stretch if you breath on them.
79 931 Euro stock
88 924S SE
87 911 Targa stock
Rich H
PostPosted: Tue Jan 08, 2008 8:14 pm    Post subject: Reply with quote
If its that bad I would get another sender...
I just fixed all the electrics to and from the sender and gauge and my fuel gauge read full instead of 50%
PostPosted: Sat Jan 19, 2008 9:42 pm    Post subject: Reply with quote
Horrible rainy day here in Sydney, and my fuel gauge had been nagging me for a while... I'd read this when Rich first posted it and thought "yup, gotta check that out".
5 minutes later - fantastic result!
Thanks!
Rich H
PostPosted: Sat Jan 19, 2008 9:59 pm    Post subject: Reply with quote
Happy to help!
kojab
PostPosted: Sun Jan 27, 2008 8:59 am    Post subject: Reply with quote
I have just read this thread and decided to give it ago as my fuel gauge has never worked properly from the day I took ownership. This is certainly an easy one to get too. Noticed that two of the spade terminals themselves had slight movement normally held with what looked like rivets on the top of the sender unit. Sprayed some japanese contact rejuvenator on loose rivets and spade connectors and now fuel reading on gauge has never read so high.
Now I will go and fill the tank and see if it reads full.
Thanks Rich H
1979 931 Supercharged EFI. Delco conversion.
Toyota SC14 Blower, 12.5 PSI. Front mount intercooler.
PostPosted: Sun Jan 27, 2008 2:59 pm    Post subject: Reply with quote
I'll put a copy of this in the How-To.
