stang Guest
Posted: Thu Jun 13, 2002 5:39 am Post subject: |
the mechanic working on the 931 said there is a fuse he can take out and the batt. will not go down but neither will the car start.
Any ideas?
numbers Guest
Posted: Thu Jun 13, 2002 6:25 am Post subject: |
| I had the same problem with my 931, and I traced it to a shorted diode in the alternator. |
924 turbo Guest
Posted: Thu Jun 13, 2002 6:33 am Post subject: |
If you've got it traced to a single circuit, you can just try to follow the wires and find the short.
larso Guest
Posted: Mon Jun 17, 2002 8:12 pm Post subject: |
Yup find out which fuse it is. The problem with shorts is that there are many possibilities. Looks like you've narrowed it down so test all the stuff hooked up to that particular fuse with an ohm meter to find the problem and it will be an easy fix.
Remember though, not to use an ohm meter on the ignition brain under the steering column if the fuse is hooked up to that. Can't pass electricity through certain circuits, will fry stuff like static in a computer. |
