Petrovich
Joined: 27 Sep 2005 Posts: 235 Location: Rockville, MD
Posted: Wed Dec 12, 2007 2:34 am Post subject: Common things to leak oil around the oil filter |
It drips oil when running, and it actually makes smoke while doing so. What are the most common things to leak oil around the exhaust manifold/oil filter? The filter is on tight and I'm pretty sure the leak was there before - there's a crust of gunk covering the exhaust pipe. _________________ 1982 924 Turbo, now Lemon |
Posted: Wed Dec 12, 2007 4:54 am Post subject: |
Valve cover gasket, or filler cap gasket? _________________ Toofah King Bad
Petrovich
Posted: Wed Dec 12, 2007 7:04 am Post subject: |
No, it's under the manifold, I saw fresh oil around the oil filter. There's some hose that runs next to the oil filter, could that be the case? _________________ 1982 924 Turbo, now Lemon |
Posted: Thu Dec 13, 2007 3:49 am Post subject: |
| There's an oil passage that runs between the head and the block right above the oil filter mount. It is often the cause of alleged oil filter leaks but it is really a head gasket that has failed in this area. Be sure to check *carefully* where the oil is coming from and if it is above the filter mount and below the manifold, be sure to carefully check the seam between the head and block. |
Petrovich
Posted: Thu Dec 13, 2007 4:13 am Post subject: |
Ohh crap you just made my day
I'll check it on the weekend. If that thing needs a head gasket, I might as well mothball it till spring. _________________ 1982 924 Turbo, now Lemon |
endwrench
Posted: Thu Dec 13, 2007 7:24 am Post subject: |
Excuse my ignorance on the workings of 931's but isn't there an oil filter adapter and some oil cooler lines in that same area of concern?
tuurbo
Joined: 08 Aug 2007 Posts: 1446 Location: East Windsor, New Jersey
Posted: Thu Dec 13, 2007 7:34 am Post subject: |
| I've had people replace the filter and not tighten it properly - believe it or not. |
Tigger937
Posted: Thu Dec 13, 2007 9:49 am Post subject: |
Another possibility: There's an "O-ring" between the oil filter mounting plate and the block that "flattens" out over time and begins to leak. Replace the "O-ring". Don't know that it would necessarily cause smoking though.
Could also be the "O-ring" in the turbo oil feed line. That is a very special high temperature "O-ring" that is made of viton (I think that's the name of it). Anyway, it's green colored and still available from Porsche for approx. $4. It usually gets incorrectly replaced by an "O-ring" of standard composition and therefore doesn't last very long. A leak there could cause smoking as the oil would tend to leak on the hot turbine and exhaust pipe. _________________ 1981 931 (Concours)
1982 931 (Daily Driver)
"Think outside the box" |
Buwani 931
Joined: 31 May 2004 Posts: 308 Location: Napa California
Posted: Thu Dec 13, 2007 10:10 am Post subject: |
| tuurbo wrote: | | I've had people replace the filter and not tighten it properly - believe it or not. |
or have the filter gasket from the old filter come off and stick to the mounting. No need to ask me how I know. It wasnt on my 924 and it was many years ago but it was one of those things that wont happen again.
Shawn _________________ 1980 931
That's thirty minutes away. I'll be there in ten. |
Petrovich
Posted: Fri Dec 14, 2007 12:25 am Post subject: |
Thank you all for the replies! I'll check those points. Hopefully it's me being dumb and leaving the filter loose or something trivial like that. _________________ 1982 924 Turbo, now Lemon |
macBdog
Posted: Fri Dec 14, 2007 2:03 pm Post subject: |
Turbo oil supply would be my first port of call. I had a hairline crack in mine so the car would smoke badly on hard left turns only. _________________ 1979 931 with a 350 chev
1973 911E with EFI
Posted: Fri Dec 14, 2007 4:01 pm Post subject: |
| macBdog wrote: | | Turbo oil supply would be my first port of call. |
+1, DOH missed that it was a 931. _________________ Toofah King Bad
Petrovich
Posted: Thu Dec 27, 2007 1:22 am Post subject: |
I'm a dumbass.
Rasta was right the first time, a flashlight to the back of the head revealed a squished, cracked gasket and the oil equivalent of Niagra Falls. Oil then leaked down and around all the stuff, making it look like the whole car leaks under the exhaust manifold.
Of course, that doesn't mean that my other stuff doesn't leak, but at least I should stop smoking like a locomotive.
Wanted to fix it yesterday, but, alas, auto stores are closed on christmas  _________________ 1982 924 Turbo, now Lemon |
