Common things to leak oil around the oil filter
Petrovich
PostPosted: Wed Dec 12, 2007 2:34 am    Post subject: Common things to leak oil around the oil filter Reply with quote
It drips oil when running, and it actually makes smoke while doing so. What are the most common things to leak oil around the exhaust manifold/oil filter? The filter is on tight and I'm pretty sure the leak was there before - there's a crust of gunk covering the exhaust pipe.
1982 924 Turbo, now Lemon
PostPosted: Wed Dec 12, 2007 4:54 am    Post subject: Reply with quote
Valve cover gasket, or filler cap gasket?
Petrovich
PostPosted: Wed Dec 12, 2007 7:04 am    Post subject: Reply with quote
No, it's under the manifold, I saw fresh oil around the oil filter. There's some hose that runs next to the oil filter, could that be the case?
PostPosted: Thu Dec 13, 2007 3:49 am    Post subject: Reply with quote
There's an oil passage that runs between the head and the block right above the oil filter mount. It is often the cause of alleged oil filter leaks but it is really a head gasket that has failed in this area. Be sure to check *carefully* where the oil is coming from and if it is above the filter mount and below the manifold, be sure to carefully check the seam between the head and block.
Petrovich
PostPosted: Thu Dec 13, 2007 4:13 am    Post subject: Reply with quote
Ohh crap you just made my day
I'll check it on the weekend. If that thing needs a head gasket, I might as well mothball it till spring.
endwrench
PostPosted: Thu Dec 13, 2007 7:24 am    Post subject: Reply with quote
Excuse my ignorance on the workings of 931's but isn't there an oil filter adapter and some oil cooler lines in that same area of concern?
Todd
tuurbo
PostPosted: Thu Dec 13, 2007 7:34 am    Post subject: Reply with quote
I've had people replace the filter and not tighten it properly - believe it or not.
Tigger937
PostPosted: Thu Dec 13, 2007 9:49 am    Post subject: Reply with quote
Another possibility: There's an "O-ring" between the oil filter mounting plate and the block that "flattens" out over time and begins to leak. Replace the "O-ring". Don't know that it would necessarily cause smoking though.
Could also be the "O-ring" in the turbo oil feed line. That is a very special high temperature "O-ring" that is made of viton (I think that's the name of it). Anyway, it's green colored and still available from Porsche for approx. $4. It usually gets incorrectly replaced by an "O-ring" of standard composition and therefore doesn't last very long. A leak there could cause smoking as the oil would tend to leak on the hot turbine and exhaust pipe.
1981 931 (Concours)
1982 931 (Daily Driver)
"Think outside the box"
Buwani 931
PostPosted: Thu Dec 13, 2007 10:10 am    Post subject: Reply with quote
or have the filter gasket from the old filter come off and stick to the mounting. No need to ask me how I know. It wasnt on my 924 and it was many years ago but it was one of those things that wont happen again.
Shawn
That's thirty minutes away. I'll be there in ten.
Petrovich
PostPosted: Fri Dec 14, 2007 12:25 am    Post subject: Reply with quote
Thank you all for the replies! I'll check those points. Hopefully it's me being dumb and leaving the filter loose or something trivial like that.
macBdog
PostPosted: Fri Dec 14, 2007 2:03 pm    Post subject: Reply with quote
Turbo oil supply would be my first port of call. I had a hairline crack in mine so the car would smoke badly on hard left turns only.
1979 931 with a 350 chev
1973 911E with EFI
p-talk wrote:
I'm still convinced the word 'Porsche' makes people crazy in all kinds of ways
PostPosted: Fri Dec 14, 2007 4:01 pm    Post subject: Reply with quote
+1, DOH missed that it was a 931.
Petrovich
PostPosted: Thu Dec 27, 2007 1:22 am    Post subject: Reply with quote
I'm a dumbass.
Rasta was right the first time, a flashlight to the back of the head revealed a squished, cracked gasket and the oil equivalent of Niagra Falls. Oil then leaked down and around all the stuff, making it look like the whole car leaks under the exhaust manifold.
Of course, that doesn't mean that my other stuff doesn't leak, but at least I should stop smoking like a locomotive.
Wanted to fix it yesterday, but, alas, auto stores are closed on christmas
