EFI question...
Rich H
PostPosted: Mon Nov 26, 2007 3:41 am    Post subject: EFI question... Reply with quote
Hey guys,
One for the EFI wizards:
What is the best way of getting plug leads to fit the EDIS coil unit? I have a nice set of nearly new BERU leads complete with nice heat shields I would like to keep but they don't fit the coilpack. The dizzy end plugs screw off, can they be replaced easily with the right plugs?
Or do I just replace the lot?
Cheers
Rich
Min
PostPosted: Mon Nov 26, 2007 3:54 am    Post subject: Reply with quote
I just bought some EDIS plug wires.
Lizard had some made up custom at a local plug wire manufacturer. (aurora)
I'm sure you could make up a set with what you've got, but you'd have to find the coil plug ends someplace. I wasn't able to find any myself.
Min
Rich H
PostPosted: Mon Nov 26, 2007 4:10 am    Post subject: Reply with quote
Fair enough, I'll file the BERU ones for now then.
Cheers
Rich
PostPosted: Mon Nov 26, 2007 6:13 pm    Post subject: Reply with quote
So, Rich, you doing the squirt and spark all in one go, eh?
I'd try getting the EFI running on standard ignition, then go over to the EIDS.
But, then, I'm a bit of an old woman.
Rich H
PostPosted: Mon Nov 26, 2007 8:10 pm    Post subject: Reply with quote
Yeah, I should really, but its going to be a fair amount of work to get it running full stop then another load of work to change everything over...
What I might do is get everything in place but not connected up. Get it running on a single coil then change over to EDIS
I need to re-wire the MS too to get it to work. Means the car will be off the road for a bit longer now but alot less when I change to EDIS.
That is if I can get it to run!!
