kevmcc
Posted: Sun Nov 18, 2007 11:39 am Post subject: engine fire |
here's a question for my fellow 924 fans
i bought an 87 924 and had a reputable porsche mechanic change a head gasket for me.
the first long trip i took after the repair (one week later) the car caught fire and was totalled because of a hole in the camshaft cover. (see attached image)
http://www.flickr.com/photos/20996120@N04/
needless to say this hole was not there when i left on my trip.
i am no mechanic but my guess is the tech tightened the camshaft cover bolts beyond their torque, this caused a weakness in the metal of the cover which cracked when hot.
neither the mechanic nor i have ever seen anything like this, but, more importantly, the mechanic is adamant this hole has nothing to do with his head gasket repair, and is refusing to refund the head gasket repair bill.
prior to the repair the car was driven 125,000 miles without incident.
any thoughts or similar experiences (the hole, not the mechanic).
[/img]
Posted: Sun Nov 18, 2007 12:01 pm Post subject: |
I've never seen damage like that before!! BTW that's the camshaft housing.
Did someone hit it with a hammer, or drop it? The bolts would strip the threads in the head long before overtightening them could cause that damage. _________________ White 87 924S "Ghost"
Posted: Sun Nov 18, 2007 12:06 pm Post subject: |
Wow, that's nutty, eh? I'm going to throw a wild scenario out there and say something hard was left under the valve cover that eventually bounced its' way over then got between the cam and the cover, that cam lobe came around and popped it through the cover. How's that sound?
How does that cause a fire though? -Or it did it cause one to get so pissed-off that they set their own car on fire?  _________________ "..it's made in Germany. You know the Germans always make good stuff."
Posted: Sun Nov 18, 2007 12:13 pm Post subject: |
Oil burns very well....especially after the fire burns through the fuel hoses. _________________ White 87 924S "Ghost"
Posted: Sun Nov 18, 2007 12:14 pm Post subject: |
There's not much evidence of a fire in those pictures. Probably caused a lot of smoke though. _________________ White 87 924S "Ghost"
kevmcc
Posted: Sun Nov 18, 2007 12:16 pm Post subject: |
yes, the oil spewing out the camshaft caught fire and the car was history.
all i know is this:
i checked oil and water before leaving on a three hour trip, car drove fab for first two hours then caught fire. hole was not there when i checked fluids...i would have seen it....
no unusual noises from engine prior to fire.... |
Posted: Sun Nov 18, 2007 12:18 pm Post subject: |
Did the car continue to run normally until you shut it off? _________________ White 87 924S "Ghost"
RC
Posted: Sun Nov 18, 2007 12:25 pm Post subject: |
Oh sh!t
Agree with Smoothies hypothesis. Not a forensic scientist but due to the outward taper on the edges of the hole conclude that the impact was from inside rather than outside.
Would suggest having a qualified independent engineer remove the cam cover and photograph any evidence such as a set of feeler gauges or spanner that was left inside. Then see a good attorney.
Roger |
endwrench
Posted: Sun Nov 18, 2007 12:34 pm Post subject: |
That is a strange one. Being a mechanic I may be a little biased but I think the he correct until you can prove otherwise. This is definetly not a standard failure. I also think smoothie is on to something. It looks to me what ever poked that hole came from the inside. You need to pull that cover and see if it still in there. The mechanic may have left a wrench or socket under the cover. If you don't have a broken or missing part in there I would be more apt to point the finger at the mechanic.
Posted: Sun Nov 18, 2007 12:42 pm Post subject: |
Todd, I agree that where I was headed by asking if the car kept running normally which would imply that it was not a broken cam lobe or lifter. _________________ White 87 924S "Ghost"
Tigger937
Posted: Sun Nov 18, 2007 12:47 pm Post subject: Re: engine fire |
| kevmcc wrote: | | i bought an 87 924 and had a reputable porsche mechanic change a head gasket for me. |
Why was the head gasket changed?
If the hole was caused by something left inside as Smoothie suggests (which sounds entirely possible), there should be some residual evidence under that cover and possibly in the oil, i.e., left over bits of metal, scratches/gouges etc. You need to have a peak inside while keeping very good documentation/evidence every step of the way. I'd have the mechanic who performed the work remove the cover while you and a witness stand by and observe.
The only way I see this starting a fire is oil getting on the hot exhaust manifold, but I think that's stretching things a bit. The oil would almost have to be squirting on there continuously to ignite. Sounds a bit weird. Where's the fire damage? I suppose oil could have saturated the hood insulation and achieved ignition, but there should be evidence of that. _________________ 1981 931 (Concours)
1982 931 (Daily Driver)
"Think outside the box" |
joecitizennn
Posted: Sun Nov 18, 2007 1:20 pm Post subject: I have "seen" that before. |
I have "seen" that before. I didnt actually see it, but I had a fellow describe the incident to me in great detail. He was heading down the interstate in a 944 and all of a sudden there was a bang, and a huge smoke cloud started spewing from his car. He shut the engine off and coasted off an exit ramp, popped the hood and jumped out. No sooner did he look into the engine compartment the grass and pool of oil under the car caught fire. He jumped back in the car, started it up and backed onto the pavement and away from the grass fire(yeah the car still ran). The car never caught fire, and he replaced the cam tower and got alot of driving out of the car yet.
What happened was a bolt came loose inside the tower and the cam shoved it through the housing. The oil gushed out onto the exhaust. Until now that is the only occence like that I had ever heard of.
My opinion, is that your mechanic did not properly torq one of the upper cam tower bolts and it vibrated out and got in a dispute with the cam. _________________ 87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
89 turbo S LSD, ABS etc
86 951 white rocket
85 944 sport everything.
84 944 sold.
87 944 sold |
Posted: Sun Nov 18, 2007 1:59 pm Post subject: |
| Smoothie wrote: | | . . .something hard was left under the valve cover that eventually bounced its' way over then got between the cam and the cover, that cam lobe came around and popped it through the cover. |
+10. If you still have the car, you should be able to open the cam box and find the missing part that got caught between the side of the box and the lobe (assuming it was a part from your car and not something else).
Your mech is full of shit, he simply doesn't want to buy you a new cam box. _________________ Toofah King Bad
joecitizennn
Posted: Sun Nov 18, 2007 2:10 pm Post subject: |
If it was not a improperly tightened bolt, it may have been a dropped bolt. Changing the cam tower can be a bitch, because you have to use a long allen estension to reach the bolts within the cover. You need to put grease on the tool to keep the bolt from falling into the tower. He may have dropped a bolt, could not get it with his magnet, and thought "f*k it" nobody will notice, and put the cap back on.
I would tell him you know what happened to your car, and ask him what he is going to do about it. _________________ 87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
86 951 white rocket
84 944 sold.
87 944 sold |
sparky
Posted: Sun Nov 18, 2007 2:36 pm Post subject: |
Get a certified mechanic to strip and document everything when your in the discovery stage, then when you find the fault, take all your documentation to your previous mechanic and try and recover all your costs.. You can get your mechanic to watch if he wants, that way there will hopefully be less friction. But remember, the most important thing is you were not injured in anyway, besides cars can be fixed
Good luck with all this.. Its very unlucky experience
Welcome to the coolest board on the planet btw  _________________ When the checkered flag drops... The Bull$hit Stops
1976 Euro 924 (The 945) - Full 951 Brakes/Suspension
1998 Boxster with goodies
2002 3.0 Xtype 4wd sport |
