Oz 924 standard rims Tyre recommendation
paulh
PostPosted: Tue Nov 13, 2007 12:26 pm    Post subject: Oz 924 standard rims Tyre recommendation Reply with quote
Hi, I'm getting close to my 1981 924 being back on the road interested if any one can recommend some tyres for me. It has standard rims and I would like to maintain an original look.
TAI
PostPosted: Tue Nov 13, 2007 12:33 pm    Post subject: Reply with quote
I think mine were 185's 14 inch.
Forgot the profile maybe 70
paulh
PostPosted: Tue Nov 13, 2007 12:37 pm    Post subject: Reply with quote
Thanks, any brand recommendation?
PostPosted: Tue Nov 13, 2007 4:42 pm    Post subject: Reply with quote
your choice for the conditions- put ya location in ya profile.
PostPosted: Tue Nov 13, 2007 5:57 pm    Post subject: Reply with quote
+1
Standard factory fit was 185/70/14
(A bit of a tall profile in my view, but someone at Porsche presumably knew what he was doing...)
Raceboy
PostPosted: Tue Nov 13, 2007 6:14 pm    Post subject: Reply with quote
I would go 195/60 R14, looks much better and retains stock profile height.
By brand? If you like to DRIVE 924, choose Yokohama AVS Sport or similar.
'83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
paulh
PostPosted: Thu Nov 15, 2007 11:04 am    Post subject: Reply with quote
Thanks for that, going for the 195/60 R14 Yokohama.
Mont Macedon Victoria Australia
1981 942 NA was brown now red- soon to be an Electric Porsche
PostPosted: Thu Nov 15, 2007 6:29 pm    Post subject: Reply with quote
Good choice!
zimm
PostPosted: Thu Nov 15, 2007 7:40 pm    Post subject: Reply with quote
195/60's dont retain stock OD.. they look tiny and i got my toofah upto 140mph on the clock with them fitted ..
did handle better though
6 bikes, 9 cars, 1 van.... the more you have the less they work.
paulh
PostPosted: Thu Nov 15, 2007 8:10 pm    Post subject: Reply with quote
got me worried now, so 195/60 won't give standard ride height/diameter? I've only ordered them - maybe I will need to see one on..
PostPosted: Thu Nov 15, 2007 9:09 pm    Post subject: Reply with quote
No... you'd want a 65 profile to retain the stock o.d.
paulh
PostPosted: Thu Nov 15, 2007 9:15 pm    Post subject: Reply with quote
do I want to go to 65?
PostPosted: Thu Nov 15, 2007 9:46 pm    Post subject: Reply with quote
A 195/65 will give the same ride height/diameter as a 185/70 (within a few mm), if that's your main concern.
On the other hand, if you go for a 195/60:
the car will sit 1/2" lower
the wheel arch gap above the tyre will increase by 1/2"
your gearing will be about 5% shorter (which will give 5% better acceleration)
your speedo will read 5% high (assumming it reads correctly now! )
your odometer will start to read 5% quicker (i.e. notch up another 100 kms after only 95)
your cornering grip may be slightly improved (due to lower C of G)
your fuel comsumption will go up a bit (i.e. you will lose ecconomy)
your top speed will be reduced (by 6 - 7 mph, ~10 kms/hr)
The choice is yours...
PostPosted: Fri Nov 16, 2007 11:46 am    Post subject: Reply with quote
I think 195/65 was the standard size here in Oz. Problem now is it's a bit hard to find quality tyres in that size.
paulh
PostPosted: Fri Nov 16, 2007 1:01 pm    Post subject: Reply with quote
Well, I took the 195/65 option, Yokohama.
the look very "right" the speedo is just as inaccurate as it ever was (GPS checked), the gearing is perhaps a little bit shorter. But the tyres have transformed the car.
Thanks for the advice.
