"Steam Cleaning" the Engine
AndyR
PostPosted: Tue Nov 13, 2007 8:52 am    Post subject: "Steam Cleaning" the Engine Reply with quote
I've noticed that using Seafoam or similar products to clean the engine has been mentioned several times already, but I've also read about using plain distilled water to eliminate engine carbon deposits as well (read it here). I'm planning to run 2 liters of distilled water through slowly at a 3000 rpm, but I'm not sure where to hook the water up to. Has anyone done this with water already?
-White 1987 Porsche 924S (Hawaii)
-Black 2000 Audi A4 (Mainland)
Min
PostPosted: Tue Nov 13, 2007 2:39 pm    Post subject: Reply with quote
I've done it, It works as descibed in that post. I've done it to a few different cars with varying results (depends how carboned up things are)
Hook the water up to any vaccum source. And don't worry about it when the car runs really bad while your feeding it in.
Min
PostPosted: Tue Nov 13, 2007 3:40 pm    Post subject: Reply with quote
In ran Seafoam through the intake on my Jeep, and it seemed to work as advertised. The white billowing cloud produced was visible from space.
StienbargerR
PostPosted: Tue Nov 13, 2007 3:46 pm    Post subject: Reply with quote
I did the seafoam treatment on my car, I dont know how well it cleaned it out, but there sure was a heck of alot of smoke!
Ryan
1978 924 NA
Vince Ponz
PostPosted: Tue Nov 13, 2007 11:04 pm    Post subject: Reply with quote
I forgot the name of the product but while a teen I used a intake cleaner too. I sprayed it into the carb for a couple of minutes reving the engine while spraying. I looked up and the entire block was filled with white smoke. I shut the hood and walked away not wanting them think I did it.
Laughed for the entire day.
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock
Tigger937
PostPosted: Wed Nov 14, 2007 4:33 am    Post subject: Reply with quote
I always knew you were an environmentalist at heart.
1981 931 (Concours)
1982 931 (Daily Driver)
"Think outside the box"
Broombroom
PostPosted: Fri Nov 16, 2007 9:47 am    Post subject: Reply with quote
When I was a lad, we used Red X in a similar way, it was so effective I used to have to turn down the idle speed.
'81 932
'85 924 Cabriolet
Vince Ponz
PostPosted: Fri Nov 16, 2007 9:51 pm    Post subject: Reply with quote
At that time Abe Lincoln and I could not care less about the environment.
No body else cared either.
79 931 Euro stock
88 924S SE
87 911 Targa stock
