what can i replace the fuel accumulators with
germ924
PostPosted: Wed Nov 07, 2007 11:54 pm    Post subject: what can i replace the fuel accumulators with Reply with quote
i have one new and one that leaks like crazy, I would like to replace and do with out, I don't know what the psi output is in order to put in an electic pump and or [u]if it is a smart idea[/u].
PostPosted: Thu Nov 08, 2007 12:51 am    Post subject: Reply with quote
You can't remove the fuel accumulators without affecting the engine start performance. The fuel accumulators are there to hold pressure in the fule system after the engine is shut down. If you remove the fuel accumulators it will be harder to start the car, and the car may suffer from vapor lock when you shut it down hot.
What size fuel accumulators do you have now?
You might be able to get away with one large one. But one small one would be too little capacity.
germ924
PostPosted: Thu Nov 08, 2007 11:49 am    Post subject: Reply with quote
both are stock, but i have access to a bigger one that is at least an inch long, not sure what it goes to, my friend has it at his salvage yard. do you need pics?
Tigger937
PostPosted: Thu Nov 08, 2007 2:49 pm    Post subject: Reply with quote
As a secondary function to gohim's comments, I believe the accumulator also serves to provide dampening of transients in the fuel system.
1981 931 (Concours)
1982 931 (Daily Driver)
"Think outside the box"
PostPosted: Fri Nov 09, 2007 2:20 am    Post subject: Reply with quote
I know the stock units are expensive, but they solved a ton of issues in my 931. What if you go to the trouble of adapting a non-stock unit from the salvage yard and it doesn't work either?
RonDwyer82-931
PostPosted: Mon Nov 12, 2007 7:11 am    Post subject: Reply with quote
I got a used one for $75 at Parts Heaven. The Bosch P/N 0-438-170-024 accumulator only fits the 79-82 924 and the 80-82 931
