Timing belt tensioner pulley question...
BTMF
PostPosted: Mon Nov 05, 2007 7:43 am    Post subject: Timing belt tensioner pulley question... Reply with quote
Today we started to replace the timing belt, and tensioner and ran into a bit of confusion. The new tensioner does not appear to be the same part as the one we removed.
The old pulley has a large nut on the face, and the new part seems to require a special tool. Obviously I'm new to the world of car repairs, and I'm not sure how to proceed. Any help would be appreciated.
Cheers!!
1977 294 n/a
...I've still got all my fingers, but somewhere I've lost my mind...
View user's profile Send private message Visit poster's website AIM Address Yahoo Messenger MSN Messenger
Martijnus
PostPosted: Mon Nov 05, 2007 7:57 am    Post subject: Reply with quote
mine looks like the new one...
I guess those holes are meant for inserting a boom-tool to accurately tension the belt.
sidequestion: does anyone know if there are plug&play tension rollers which can tension 'more'... or larger roll...? My head lies 1mm lower (machined engine block) which gives 2mm more play on my belt...
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
PostPosted: Mon Nov 05, 2007 8:28 am    Post subject: Reply with quote
The new pulley is the part that superceeded the original part that you removed from your engine.
The new part is also used on watercooled VWs and there is a special tool (about $10-$15) made for adjusting the belt tension. You should be able tool at most decent VW shops, or you can also use a bicycle bottom bracket (crank) tool.
You will need a longer bolt, and a washer to install the new belt tensioner.
PostPosted: Mon Nov 05, 2007 6:27 pm    Post subject: Reply with quote
Actually, the bolt needs to be shorter. The VW unit is about 1/2" shorter/thinner due to not having the hex nut adjuster.
I think Smoothie posted a thread on how to make an adjustment tool for the VW unit. I'll see if I can find it.
PostPosted: Mon Nov 05, 2007 6:40 pm    Post subject: Reply with quote
I bought this spanner
http://mdmetric.com/sw/stahlwillehdr2.htm
johnathan1
PostPosted: Mon Nov 05, 2007 8:36 pm    Post subject: Reply with quote
Wow, mine doesn't look like either of those.
-1977 924, 4-Spd...Gone
-1987 Toyota Supra Turbo, Pearl White, BPU, 300RWHP @ 10psi.
-1989 Mercedes-Benz 300SEL
WARNING: MAY CONTAIN TRACES OF AUDI OR VW!
zimm
PostPosted: Mon Nov 05, 2007 8:37 pm    Post subject: Reply with quote
i just used a large screwdriver to "lift" the tensioner into position by levering it against the top of water pump, then tightened the center bolt.
also .. i just used some washers to space out the original bolt .. works fine
6 bikes, 9 cars, 1 van.... the more you have the less they work.
PostPosted: Mon Nov 05, 2007 9:04 pm    Post subject: Reply with quote
Yeah, I did that at first, but you need a lot of washers (and it looks naff!)
Martijnus
PostPosted: Mon Nov 05, 2007 10:04 pm    Post subject: Reply with quote
I usually look very angry and command the tensioner to tension or else..
works fine
PostPosted: Tue Nov 06, 2007 6:02 pm    Post subject: Reply with quote
Can you walk on water, too?
Martijnus
PostPosted: Tue Nov 06, 2007 9:17 pm    Post subject: Reply with quote
sometimes... if the weather's right
