germ924
Joined: 04 Aug 2006 Posts: 233 Location: chino valley, Arizona
Posted: Wed Oct 31, 2007 1:26 pm Post subject: mystery 2.0 |
did or does your 2.0 have this.
I found one today at the junk yard in what i think is a motor out of an audi.
because mine doesn't have one. do i need one?
the motor i found is not in a car and it some differences. like the valve cover looks modern and the oil pan is just a steel pan but the head and block is the same. oh and it has a electronic plug on the oil filter attachment. i haven't looked to see if mine has it.
what is your feed back on this mystery. |
Posted: Wed Oct 31, 2007 2:53 pm Post subject: |
Please offer link with download to decrypting software. _________________ 3 928s, |
968rz
Joined: 21 Aug 2006 Posts: 537 Location: S. E. Wisconsin
Posted: Wed Oct 31, 2007 3:02 pm Post subject: Re: mystery 2.0 |
| germ924 wrote: | did or does your 2.0 have this.
ummmmmmmm, yes?
+ plus 1 on the decryption package.  _________________ Rick
93 968 coupe Amazon Green 4spd Tip (my DD) |
Posted: Wed Oct 31, 2007 3:09 pm Post subject: |
Ask and you shall receive.
| germ924 wrote: | did or does ya’lls 2.0 haz this.
I found one todey at da junk yard in wa’tch meh think iz a motor out o’ an audi.
because mine doesn’t haz one. do meh need one?
the motor meh found iz no way in a lo rider an’ da thang some differences. like da valve cover looks modern an’ da oil pan iz just a steel pan but da head an’ block iz da same. oh an’ da thang haz a electronic plug on da oil filter attachment. meh haven’t looked ta see if’in mine haz da thang.
what iz ya’lls feed back on this mystery. |
Posted: Wed Oct 31, 2007 5:54 pm Post subject: |
Yes, pre-1982 (USA, 1985 RoW) 924s have a 2.0 Audi engine.
Yours will need one, too. If it doesn't have one, put one in. _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
germ924
Posted: Thu Nov 01, 2007 12:01 am Post subject: |
man, I skipped a whole sentence, that was a strong drink last night i guess,
there was a plastic cover under the valve cover, it covers the cam.
do i need one on my motor because i don't have one |
Posted: Thu Nov 01, 2007 12:03 am Post subject: |
Not ever seen one on a 924 mill... _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
Viking
Joined: 30 Jan 2003 Posts: 107 Location: Oslo, Norway
Posted: Thu Nov 01, 2007 6:26 pm Post subject: |
| I haven't seen a plastic cover that covers the cam on any of the three 924 engines I've seen, and not on my spare head & block from an Audi either. |
Posted: Fri Nov 02, 2007 5:50 am Post subject: |
| Sounds like this guy is describing the shielding plate installed on later VW and Audi 1.8L engines to help keep oil splash on the camshaft instead of letting it spray onto the valve cover (and out of the oil filler cap if you open it while the enigne is running). |
germ924
Posted: Fri Nov 02, 2007 11:10 am Post subject: |
| gohim, that is exactly what it is. should i use it. the motor is a 2.0 though. it was stamped. I have the motor. |
Posted: Fri Nov 02, 2007 12:06 pm Post subject: |
Did you compare the mounting holes with the 924's camshaft mounting bolts?
I have not checked myself, but if you do, you might find that the holes are the wrong distance apart |
Posted: Fri Nov 02, 2007 6:33 pm Post subject: |
Make sure it fits on above the oil tube!  _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
germ924
Posted: Sat Nov 03, 2007 12:07 am Post subject: |
| ill need to pull my valve cover, ill check and see if it fits, next time i pull it off, which hopefully isn't for a bad thing |
