mystery 2.0
germ924
PostPosted: Wed Oct 31, 2007 1:26 pm    Post subject: mystery 2.0 Reply with quote
did or does your 2.0 have this.
I found one today at the junk yard in what i think is a motor out of an audi.
because mine doesn't have one. do i need one?
the motor i found is not in a car and it some differences. like the valve cover looks modern and the oil pan is just a steel pan but the head and block is the same. oh and it has a electronic plug on the oil filter attachment. i haven't looked to see if mine has it.
what is your feed back on this mystery.
PostPosted: Wed Oct 31, 2007 2:53 pm    Post subject: Reply with quote
Please offer link with download to decrypting software.
3 928s,
968rz
PostPosted: Wed Oct 31, 2007 3:02 pm    Post subject: Re: mystery 2.0 Reply with quote
ummmmmmmm, yes?
+ plus 1 on the decryption package.
Rick
93 968 coupe Amazon Green 4spd Tip (my DD)
PostPosted: Wed Oct 31, 2007 3:09 pm    Post subject: Reply with quote
Ask and you shall receive.
germ924 wrote:
did or does ya’lls 2.0 haz this.
I found one todey at da junk yard in wa’tch meh think iz a motor out o’ an audi.
because mine doesn’t haz one. do meh need one?
the motor meh found iz no way in a lo rider an’ da thang some differences. like da valve cover looks modern an’ da oil pan iz just a steel pan but da head an’ block iz da same. oh an’ da thang haz a electronic plug on da oil filter attachment. meh haven’t looked ta see if’in mine haz da thang.
what iz ya’lls feed back on this mystery.
PostPosted: Wed Oct 31, 2007 5:54 pm    Post subject: Reply with quote
Yes, pre-1982 (USA, 1985 RoW) 924s have a 2.0 Audi engine.
Yours will need one, too. If it doesn't have one, put one in.
germ924
PostPosted: Thu Nov 01, 2007 12:01 am    Post subject: Reply with quote
man, I skipped a whole sentence, that was a strong drink last night i guess,
there was a plastic cover under the valve cover, it covers the cam.
do i need one on my motor because i don't have one
PostPosted: Thu Nov 01, 2007 12:03 am    Post subject: Reply with quote
Not ever seen one on a 924 mill...
Viking
PostPosted: Thu Nov 01, 2007 6:26 pm    Post subject: Reply with quote
I haven't seen a plastic cover that covers the cam on any of the three 924 engines I've seen, and not on my spare head & block from an Audi either.
PostPosted: Fri Nov 02, 2007 5:50 am    Post subject: Reply with quote
Sounds like this guy is describing the shielding plate installed on later VW and Audi 1.8L engines to help keep oil splash on the camshaft instead of letting it spray onto the valve cover (and out of the oil filler cap if you open it while the enigne is running).
germ924
PostPosted: Fri Nov 02, 2007 11:10 am    Post subject: Reply with quote
gohim, that is exactly what it is. should i use it. the motor is a 2.0 though. it was stamped. I have the motor.
PostPosted: Fri Nov 02, 2007 12:06 pm    Post subject: Reply with quote
Did you compare the mounting holes with the 924's camshaft mounting bolts?
I have not checked myself, but if you do, you might find that the holes are the wrong distance apart
PostPosted: Fri Nov 02, 2007 6:33 pm    Post subject: Reply with quote
Make sure it fits on above the oil tube!
germ924
PostPosted: Sat Nov 03, 2007 12:07 am    Post subject: Reply with quote
ill need to pull my valve cover, ill check and see if it fits, next time i pull it off, which hopefully isn't for a bad thing
