Tappet noise - but from which one?
Goto page Previous  1, 2
seanski44
PostPosted: Tue Oct 30, 2007 10:59 pm    Post subject: Reply with quote
Mike924 wrote:
Thanks for the replies, Guys (...and JAF).
Not driving, Nobbi, just with the engine at idle speed, to take a look.
Thanks, Tigger: I'll give it a go!
Porchev and 924Guy: I set the clearances (with a feeler guage) a few months ago. I think I did it right, but I could have cocked up. And, for sure, I'll check with a feeler gauge again when I take the cover off, before starting her up!
Morghen, I have a stethoscope, such as you describe especially for motors. I used it on an earlier car and got such a fright from all the noises going on, I haven't dared use it again!
Hi Mike,
Not sure if you remember my tappet issues in the past (more than I year since I waved goodbye to the 24 ) but this sounds similar.
What I'd mention from my experiences is that the wear could easily be on the bucket and the buckets rotate and aren't nec uniform, so try checking your clearances again and as you check each one swivel the bucket around as you do... best of luck!
I have to confess, due to my prior problems with stripping threads on the dizzy drive housing I resorted to the BALS* method of repair
*Buy A Louder Stereo
Not proud of it, but never managed to fix it!
1998 BMW Z3 2.8 arctic silver & red
1981 168HP 931 S2 blue/tan leather - SOLD
1985 121HP 924 2.0l na modded - SOLD!
1992 968 lux SOLD
1989 944 2.7 lux SOLD
PostPosted: Wed Oct 31, 2007 12:17 am    Post subject: Reply with quote
I was thinking along those lines, Sean, beacuse the noise comes and goes, then comes back, then goes again; like the bucket's rotating.
Trouble is, when you adjust the clearance you need to rotate the bucket to the right place to get the Allen key in, so naturally that's the position you measure the gap... Perhaps the thing to do is measure, rotate bucket by 90°, measure again and adjust for the average (or throw the bucket away if the difference is more than the tolerance range... )
I was kind of hoping to confirm the rotating bucket theory by watching them rotate and see when the noise is worst... , but maybe the cross measurement idea is better...
PostPosted: Wed Oct 31, 2007 12:23 am    Post subject: Reply with quote
Jaf wrote:
Will have been just idle speed. By the time I got round to the front (10 secs) there was oil all over the place so I didn't stick around to look where it was coming from. Reckon it might have been bouncing off the cam lobes as it was coming out at all sorts of angles.
Are you going to give it a try? With cardboard and rag maybe like DOCO and Tigger suggest.
What I think I'll do is cover the place with rags, leave the cam cover resting in place (with the nuts removed), start the engine and then just gently lift the cover, a bit at a time, until either it's all the way off or I think too much oil coming out, whichever happens first...
PostPosted: Wed Oct 31, 2007 1:12 am    Post subject: Reply with quote
Best grab one of these:
PostPosted: Wed Oct 31, 2007 1:13 am    Post subject: Reply with quote
Oooh... I like the yellow one!
seanski44
PostPosted: Wed Oct 31, 2007 6:07 pm    Post subject: Reply with quote
also, don't forget once you've identified the area at fault, you could try swapping the bucket with another cylinder's and see if the fault follows - would tell you if it were a cam prob or bucket prob. But I know that's a lot of work whipping the cam off!!
1992 968 lux SOLD
PostPosted: Wed Oct 31, 2007 6:37 pm    Post subject: Reply with quote
Yeah, that's just it, Sean. I don't really want to remove the cam anymore than I have to. I know it's got to come off one more time to sort out the dodgy bucket, but I'd like to limit it to that, if at all possible.
Tiny
PostPosted: Wed Oct 31, 2007 9:10 pm    Post subject: Reply with quote
Hi Mike,
Just another idea on this one. I read that you can easily identify a source of noise using a sound "cone."
Allow me to explain... Using a piece of fairly thick paper and peice of sticky tape, make a cone of about half a metre in length. For the tappet noise I'd make one end to have approx 4 inch diameter... and the other end for your ear approx 1 inch in diameter.
When you remove the cam cover and start up to idle, you can listen using the cone to your ear with greater directional accuracy for that noisy gap.
I have exactly the same noise on my car from one solitary tappet...and was thinking the bucket was spinning as the tap became more prominent on idle....so looking forward to you cracking this one! = ]
best of luck,
Tiny
PORSCHEV
PostPosted: Wed Oct 31, 2007 10:37 pm    Post subject: Reply with quote
I don't think your visually going to be able to "see" the troubled lifter..but if you must do this test why don't you plug the oiler tube with a piece of rubber hose with the other end clamped off?? That will limit alot of the oil.
1978-#53 "D" track racer.
PostPosted: Wed Oct 31, 2007 11:25 pm    Post subject: Reply with quote
You might well be right there, but at least I'll get some idea of what's going on. Not least to see if the oil tube is, in fact, lubricating every lobe.
PostPosted: Thu Nov 01, 2007 3:19 am    Post subject: Reply with quote
yea...you wont actualy see anything. you need to warm up the engine and then remove the cover and inspect each tappet by moving the cam and pressing and lifting each tappet with your fingers. also you should check with a measuring tool. I'm going to do that to my car tomorow too. i have a weird sound too
Page 2 of 2
