Email: rmaclaren@iprimus.ca
Date: 2/8/00
Time: 7:49:27 PMHi.
The nitrous was discussed until everyone almost threw up at www.pca.potomac. The die hard 'purists' say Don't install it or your clutch and engine will fly through the roof, and the 'deviants' say go ahead and install nitrous. I checked out nitrous and found there is a kit devoted to the 924. The only problem I have with installing it is that it may be best to do it with a rebuilt engine, else the worry is that it could be problemmatic for the engine. I guess the concern is compression. Also, no one is clear whether a 'wet' or 'dry' system is actually appropriate for the 924. The letters I have from NOS say "Use dry" yet 944 fans say that dry is a risk and once should use 'wet' systems. I, like you, would like to learn more...
