peebles24
Joined: 27 Jul 2007 Posts: 43 Location: Terre Haute, IN
Posted: Sun Oct 28, 2007 3:51 am Post subject: tire question? |
Has anyone tried to run 215 60 14's on their 924? It is the exact same hieght as the original 185 70 14 at 24.2 inches which makes it a hair wider and shorter than the stock 205 60 15's which are 24.7 inches. Should net some gains in handling with the wider footprint and shorter side wall. I just wonder if they would rub on the front. My 205's rubbed the front fender in Vermont under some hard driving conditions, I was doing about 55 into a hard downhill right hander while getting on the brakes, about as bad of condition as it could get with all the weight on the drivers front tire.
All opinions appreciated and I did some searching with very little luck.
Thank You,
Chad P. _________________ 1981 924 Weissach, progressive rate coils, Dansk Polished S/S exhaust, free flow Cat, K&N filter
1991 Toyota FJ80 |
Posted: Sun Oct 28, 2007 4:03 am Post subject: |
215 is a hair wide for 6' rims, IMO. _________________ Toofah King Bad
johnathan1
Posted: Fri Nov 02, 2007 1:18 pm Post subject: |
How wide are the stock spiderweb wheels? And what size tires do people usually put on them for a good combination of grip & tight handling? _________________ -1977 924, 4-Spd...Gone
-1987 Toyota Supra Turbo, Pearl White, BPU, 300RWHP @ 10psi.
-1989 Mercedes-Benz 300SEL
WARNING: MAY CONTAIN TRACES OF AUDI OR VW! |
RC
Posted: Fri Nov 02, 2007 4:58 pm Post subject: |
The standard 4 bolt spiderwebs are 6J14. These will take up to a 225 safely, according to the tyre dealers.
Currently I am running 225/60/14 Toyos on all corners with no problems or rubbing. Previously had 225/60/14 Goodyear eagles with raised lettering that would just rub on the front (swaybar I think) at full lock.
While there will be some variation between brands of the same size, am sure that 215/60/14 will be OK.
Roger |
Posted: Sat Nov 03, 2007 12:58 am Post subject: |
Well, there's a difference between whether they can be mounted and whether they provide a stable contact patch under hard cornering. . . _________________ Toofah King Bad
johnathan1
Posted: Sat Nov 03, 2007 4:07 am Post subject: |
| Rasta Monsta wrote: | | Well, there's a difference between whether they can be mounted and whether they provide a stable contact patch under hard cornering. . . |
Right...which is why I'm asking you guys what the best size to go with is...I'm guessing a 205 is a little too big? How about a 195? _________________ -1977 924, 4-Spd...Gone
Posted: Sat Nov 03, 2007 5:01 am Post subject: |
205 is good for 6" rim. Use the tire size calculator to get an idea about aspect ratios. _________________ Toofah King Bad
peebles24
Posted: Sat Nov 03, 2007 10:07 am Post subject: |
205 is stock on the 15 inch spider webs, problem is nobody makes a 205 65 14 which will keep your speedometer reading right. _________________ 1981 924 Weissach, progressive rate coils, Dansk Polished S/S exhaust, free flow Cat, K&N filter
1991 Toyota FJ80 |
Vince Ponz
Posted: Sat Nov 03, 2007 11:40 pm Post subject: |
205s _________________ "Never let them see you sweat"
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock |
zimm
Joined: 18 Oct 2006 Posts: 62 Location: Hereford, UK.
Posted: Sun Nov 04, 2007 10:28 am Post subject: |
i had 195/60/14's on mine on the stock alloys .. worked great .. cept they looked a bit small, and the speedo became somewhat optimistic  _________________ 6 bikes, 9 cars, 1 van.... the more you have the less they work. |
flosho
Posted: Sun Nov 04, 2007 12:36 pm Post subject: |
For the record..
My stock spiderwebs had 215/60 up front, and 225/60 in the rear.
Now with 16x7 and 16x8's i run only 205/55 and 225/50 _________________ [This Space For Rent] |
