dgKnecht
Posted: Thu Oct 25, 2007 7:43 am Post subject: Fuel dizzy rebuid |
anyone have any part numbers needed to replace the o-rings and gaskets in the fuel distributor? i'm gonna attempt this weekend....wish me luck lol _________________ 78 924
--all of us have been through some bad times.....i once had a job where i had to drive a Chevette  |
Tigger937
Posted: Thu Oct 25, 2007 2:01 pm Post subject: |
You are going were few have gone before. BOL. _________________ 1981 931 (Concours)
1982 931 (Daily Driver)
"Think outside the box" |
931Tony
Posted: Thu Oct 25, 2007 4:15 pm Post subject: |
dgKnecht
I actually did this not too long ago. I'll look it up tomorrow when I go by the shop. I ended up buying a metric (neoprene, not rubber) o-ring kit instead of just buying one at a time but I'll post with the part numbers tomorrow.
Good luck! _________________ 1981 931 For Sale... Sad to see her go. |
dgKnecht
Posted: Fri Oct 26, 2007 8:15 am Post subject: |
i can find the o-ring between the dizzy and the air metering assembly,
and i can find the cork gasket between the air metering assy and the air filter box, ( both shown in PET).
but i can't find that o-ring for the pressure regulator needle
hopefully that is all i'll need? _________________ 78 924
Posted: Fri Oct 26, 2007 8:50 am Post subject: |
SpecialT Auto has that one. _________________ Toofah King Bad
RC
Posted: Fri Oct 26, 2007 9:18 am Post subject: |
You wont get a list of sizes from Porsche since this whole part is intended to be replaced not rebuilt.
It can however be successfully rebuilt and all the O rings are METRIC SIZES. These are available sizes, although not all common, and may only be available at a specialist seal supplier, particularly in the USA. Measure all the existing seals with calipers and fit in with standard sizes, IIRC all single mm diameters (to 20 at least) with thicknesses of 1, 1.2,1.6,2.0,2.5,3 etc.
Some in my spares collection suggest possibly 18x1.6 and 16x1.6 on piston tube OD and 7x2 on the 4 elongated radial sleeves on the tube to upper body. This must be aligned correctly, pushed in hard while lubricated with fuel and not twisted when tightening the main nut.
Have fun.
Roger |
dgKnecht
Posted: Sun Nov 04, 2007 9:11 am Post subject: |
is that the way the alum washers go - or are they upside down?
check out all the rust, ewwwwww  _________________ 78 924
RC
Posted: Sun Nov 04, 2007 9:29 am Post subject: |
The aluminium washers are the correct way.
That rust is a worry though. Suggest scraping off the majority (in the hollows only not the bore or face) and then treating with a chemical rust dissolver or convertor. Glass beading would be the best option IMO as it will remove the rust but not damage the machined faces.
Roger |
