daveo
Posted: Tue Oct 16, 2007 4:33 am Post subject: need oil pump |
Hi all
Its time to start my race motor rebuild, as I killed it big time 4 weeks back
My first problem is, hear over in the UK you can no longer get a new oil pump as it seems they have stopped making them
Can any one help. With a supplier or contact or even one for sale
Thanks
Dave |
Chrenan
Posted: Tue Oct 16, 2007 4:49 am Post subject: |
Hi Dave,
Not sure of your intents for the rebuild, if it is highly modified or intended for racing, but the oil pump is very durable, and unless there is a problem with it you shouldn't need to replace it. Just be sure to swap in a new cylinder in the oil pressure relief valve, and a new spring in there too if you are ambitious.
Chrenan _________________ 1987 951 - M193 Version for Japan |
Chrenan
Posted: Tue Oct 16, 2007 4:55 am Post subject: |
Ahh, stupid me, I just re-read your original post. Are you worried your oil pump picked up some debris when your engine died? A used oil pump from a known good engine may be a good option? _________________ 1987 951 - M193 Version for Japan |
Joined: 29 Jul 2001 Posts: 9135 Location: Royal Oak, MI, USA
Posted: Tue Oct 16, 2007 5:39 am Post subject: |
Pop open the oil pump, if concerned, using an impact driver, and check it.
I've never used a new pump, they always seem to have plenty of output. _________________ Vaughan Scott
