germ924
Joined: 04 Aug 2006 Posts: 233 Location: chino valley, Arizona
Posted: Mon Oct 15, 2007 4:39 am Post subject: how do i lower the front |
| do i need any special tools to lower the rear adn or the front? |
Posted: Mon Oct 15, 2007 5:54 am Post subject: |
AFAIK, front ride height is dependant on your spring length and rate. The procedure for lowering the rear is in the Tech Section. _________________ Toofah King Bad
Posted: Mon Oct 15, 2007 10:42 am Post subject: |
It is. Otherwise - search on Paragon Products or the like for "coil-over kit" _________________ Vaughan Scott
joecitizennn
Posted: Mon Oct 15, 2007 1:10 pm Post subject: |
or you could just let the air out of your tires, that will get you closer to the ground. _________________ 3 928s, |
Joined: 23 Apr 2006 Posts: 1650 Location: Sydney, Australia... mate!
Posted: Mon Oct 15, 2007 2:42 pm Post subject: |
| Lizard wrote: | | or you could just let the air out of your tires, that will get you closer to the ground. |
I've seen guys do this, but incorrectly - quite obvious when you see it. The mistake is that they only let air out from the bottom of the tires... the trick is to let it out evenly, all-around the tire...
G. _________________ Whoever said you can't buy happiness forgot about Porsche!
69 911 |
!tom
Posted: Tue Oct 16, 2007 8:11 am Post subject: |
So, the key is to let the air out of the tires as they are driving down the road. Then, you can get the air out evenly! _________________ 78 924 NA
5-lug |
Posted: Tue Oct 16, 2007 10:07 am Post subject: |
Nah, you need metric air in the tires, that's what the factory used. _________________ White 87 924S "Ghost"
john h
All you need is a gas torch and two blocks of wood that give your car the required ground clearance.
Put the blocks of wood under the lower arms, heat the springs with the gas torch and when the car sags down onto the blocks of wood you’ve lowered your car. Just be careful you don’t set fire to your tires while doing this. _________________ Remember a Porsche is not just for Christmas,
joecitizennn
Posted: Tue Oct 16, 2007 1:17 pm Post subject: |
| will that adversly change the temperment of the steel in the spring? |
Posted: Tue Oct 16, 2007 1:30 pm Post subject: |
One might think. _________________ Toofah King Bad
