Turbo Replacement w/o Removing Head
Tigger937
PostPosted: Fri Oct 12, 2007 1:25 pm    Post subject: Turbo Replacement w/o Removing Head Reply with quote
Anyone ever replace their turbo AND EM without removing the cylinder head? Can it be done?
1981 931 (Concours)
1982 931 (Daily Driver)
"Think outside the box"
macBdog
PostPosted: Fri Oct 12, 2007 2:43 pm    Post subject: Reply with quote
Yup, there are lots who will tell you otherwise but I can do it in 7 hours.
1979 931 with a 350 chev
1973 911E with EFI
p-talk wrote:
I'm still convinced the word 'Porsche' makes people crazy in all kinds of ways
Tigger937
PostPosted: Fri Oct 12, 2007 3:42 pm    Post subject: Reply with quote
Impressive, that's gotta be some sort of record. Or is it that much easier on a 932? Still, that's quick.
1981 931 (Concours)
924guy
PostPosted: Fri Oct 12, 2007 7:04 pm    Post subject: Reply with quote
been there done that, couple of times.. it can definitely be done, though i think its probably easier to pull the whole engine. might not be faster, but with it out, you can get to all the bolts much easier, and do a better job of getting more accurate torque values and such when putting it back together. its also a good option if you want to give the whole thing a once over, and replace the drain lines and other stuff thats hard to get from the top or the bottom..
Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha
Tigger937
PostPosted: Sun Oct 14, 2007 9:50 am    Post subject: Reply with quote
Yeah, I hear ya and I'd really like to do it. No doubt that is the best way. Unfortunately garage space is at a premium right now.
1981 931 (Concours)
macBdog
PostPosted: Mon Oct 15, 2007 9:45 am    Post subject: Reply with quote
It is a frustrating experience. The first time I struggled bigtime - broke fingernails, plenty of skin off the back of my hands etc. The next time was a bit easier and by the fourth time I had a strategy for every nut.
A few of them required two universal joints and extensions on the ratchet. I'm sure torque values go out the window with so many transmission pieces in the way so I just do everything up "tight".
1973 911E with EFI
rdjohnston50
PostPosted: Tue Oct 16, 2007 8:04 am    Post subject: turbo replacement Reply with quote
When I bought this car, the turbo had been removed. I ended up putting another turbo back on w/o removing the head. It can be done. THe hardest part is getting the oil line to stop leaking at the top.
