Seating rings on fresh engine rebuild
RonDwyer82-931
PostPosted: Wed Sep 19, 2007 1:07 pm    Post subject: Seating rings on fresh engine rebuild Reply with quote
Well, the oil issue solved by my moms' trusty old 1950's era cannister vacuum cleaner. the gremlin was reincarnated as a rough running issue that lent itself to solution by correcting the plug wire connections (amazing how it ran on 2 cylinders without backfiring). I am a little concerned about the smoky running now, it's still on jack stands in the garage. How long do most people experience smoky acceleration before the rings seat? My caterpillar bulldozer support group recommends tossing a handful of Bon-Ami cleanser into the intake, but that is vintage 1948 technology! I put in a fresh set of fitted Deves rings on the re-assembly, but I have a sneaking suspicion I got so excited to finish the project that I never broke the glaze on the bores. Duh. Anyone have any ideas short of getting a little rough on the beaver? How long does it take to ruin a catalyst with smoky exhaust? OK, so I'm a little on the nervous side. Actually not nervous, just thrifty after the divorce.
PostPosted: Wed Sep 19, 2007 10:09 pm    Post subject: Reply with quote
Well, you can't seat the rings without load. Revving in the garage does nothing, may in fact set back your efforts to seat the rings. You need to go out and drive the car hard, put it under load, and run it through the gears...
Chrenan
PostPosted: Thu Sep 20, 2007 12:11 am    Post subject: Reply with quote
I'm with Vaughn, the engine needs load to seat the rings, it can't be done while sitting. After I rebuilt my 924 engine, I only kept it running in the garage long enough to know it would stay running. Then, I was out in the evenings when the roads were empty, up and down through the gears, lots of engine braking, full throttle runs but only to a 4000 rpm for the first 1000 km. After that, I have driven it hard, redline at least a few times each drive, and it nevers misses a beat. Uses less that the factory recommended 1 litre of oil per 1000km.
PostPosted: Fri Sep 21, 2007 11:29 am    Post subject: Reply with quote
If you did not cross hatch the cylinder walls, the rings may never seat.
If you ran it for long on 2 cylinders, you have a lot of gasoline in the oil. This may have diluted the oil to the point that it is easily getting past your rings.
RonDwyer82-931
PostPosted: Sun Sep 23, 2007 5:42 pm    Post subject: Reply with quote
I didn't run it long, and the oil has no smell of gasoline in it. I did research my invoices and did have it honed when I hot-tanked the block. A hundred miles of varying speed acceleration and mountain roads cleaned up the smoke thankfully. I'll go another hun in the morning for good measure!
RonDwyer82-931
PostPosted: Wed Oct 10, 2007 3:31 pm    Post subject: Smoking diminished Reply with quote
Seems time cured this one. I'll settle for drips over smoke any day!
