Shipped my 924 from California to Hawaii-what happened?
LBauer
PostPosted: Mon Oct 08, 2007 11:39 am    Post subject: Shipped my 924 from California to Hawaii-what happened? Reply with quote
I shipped my 79-924 from California to Hawaii. It ran great in California but once at sea level it is just having the hardest time idling. Does anyone know of any altitude adjustments necessary? Looking through my repair manual I sure don't see anything? Any Ideas?????
Neil924
PostPosted: Mon Oct 08, 2007 12:18 pm    Post subject: Reply with quote
Yeah race cars have this problem a lot.
I don't know what the measurements are but I think the higher you go, the less air density and the cars run more lean. At sea level they use more air and need more fuel, I think.
Don't quote me now but you're on the right track.
Neil924
PostPosted: Mon Oct 08, 2007 12:21 pm    Post subject: Reply with quote
It's an N/A right? {No turbo}
PostPosted: Mon Oct 08, 2007 1:27 pm    Post subject: Reply with quote
Yep, gotta richen it up a bit.
PostPosted: Tue Oct 09, 2007 2:52 am    Post subject: Reply with quote
yep, got the same problem....you just need to adjust it a bit.
Neil924
PostPosted: Tue Oct 09, 2007 3:35 am    Post subject: Reply with quote
Yeah I checked it out, try "richening" up the car. A.K.A. give the car more fuel. Also check for a vacuum leak, something could have happened during shipping.
Could you pick up an Auto meter air/ fuel gauge at a local parts store, or do they only sell alcohol and surf boards in Hawaii?
Tigger937
PostPosted: Tue Oct 09, 2007 4:04 am    Post subject: Reply with quote
Just head up Mauna Kea to confirm.
Mahalo and Aloha! A hui ho!
1981 931 (Concours)
1982 931 (Daily Driver)
"Think outside the box"
PostPosted: Wed Oct 10, 2007 3:18 am    Post subject: Reply with quote
That's interesting.
I always thought the air metering plate inherently took the air density into account based on the physics of how the fuel injection worked.
It's true carbeurators need this type of adjustment, but not fuel injected cars (mechanical or electronic), based on how they work.
The increased density of air at lower altitudes would cause an increased deflection of the air metering plate (for any throttle setting), causing a proportionally larger volume of fuel to be injected. Already compensated for!
Sounds like maybe a climate change has caused an air leak in your intake plumbing.
78 924 NA
5-lug
