berenlotr
Posted: Sun Oct 07, 2007 10:12 am Post subject: replacing bushings |
Hey i am changing out the bushings for the linkage on the tranny side. i am having a hrad time getting that pin in the coupler out, is there a trick to it or do u just drive it out of there _________________ 1979 924 N/A |
Joined: 29 Jul 2001 Posts: 9126 Location: Royal Oak, MI, USA
Posted: Sun Oct 07, 2007 10:40 pm Post subject: |
Took me a minute, till I saw you have a 79! You're talking about the u-joint near the trans, with the large (10mm OD?) pin? Yes, that needs to be driven out, tap it out with a ball peen hammer. The center is wider than the ends (which helps contribute to the slop in the shifter). _________________ Vaughan Scott
berenlotr
Posted: Mon Oct 08, 2007 3:40 am Post subject: |
thanks. i cut a hole in the floor and found, surprise surprise, no bushing left at all. replacement ended up being pretty easy and man is that shifter crisp now, what a difference _________________ 1979 924 N/A |
leadfoot
Posted: Mon Oct 08, 2007 3:34 pm Post subject: |
Can you post a picture of the hole, interested where you cut it...
thanks,
Leadfoot _________________ 1981 ROW 924 Turbo -
carbon fiber GT mish mash
berenlotr
Posted: Tue Oct 09, 2007 1:37 pm Post subject: |
i can't really get a pic right now i am back at college a couple hundred miles from my car . i cut the hole starting a couple inches up on the the hump as it inclines and it went down to the fortified part of the floor right before where the carpet starts _________________ 1979 924 N/A |
leadfoot
Posted: Wed Oct 10, 2007 9:27 am Post subject: |
same place as 924RACR's then...
http://www.vaughanscott.com/construction/trans-hump4.jpg
are there any fluid line etc you need to look out for...?
thanks,
