Camshaft?
PostPosted: Sat Oct 06, 2007 1:45 am    Post subject: Camshaft? Reply with quote
Is any body know if that would fit on my 1976 924?
http://www.neuspeed.com/products/product_details.asp?app=39|J3&type=11&ltype=ns_euro&p_id=41
Thank you[/url]
Neil924
PostPosted: Sat Oct 06, 2007 7:09 am    Post subject: Re: Camshaft? Reply with quote
Thank you[/url]
"""Add up to 10 horsepower and feel it all the way through the powerband with a NEUSPEED sport camshaft. Germany's leading camshaft maker supplies our chill cast billets which we machine to our custom specifications. Translation: it's designed specifically for your car and your level of engine modifications. Beware of inexpensive "re-grind"cams that experience premature lobe failure. Install the best -- NEUSPEED!
Notes
.438 lift / 268 duration. Mid range and high end cam. Fits OBD I engines through 1995 only. Do not use on 1996-later OBD II engines."""
When the company says "add up to 10 hp" It means "don't expect any noticeable difference". Also from what I can tell it might make your car a little sluggish from low revs.
Call or email them to find out all of the answers you want.
PostPosted: Sat Oct 06, 2007 8:22 am    Post subject: Reply with quote
Um, are you asking whether a mid-90's Jetta camshaft will bolt into your 2.0?
I'm guessing probably not. Check out Integral for a 924 cam.
