joecitizennn
Posted: Thu Sep 20, 2007 11:03 am Post subject: Will early 911 wheels fit 944? |
| will early 911 or 912 5 lug wheels fit the lug pattern of a 944 or 924S? |
9xx
Posted: Thu Sep 20, 2007 2:35 pm Post subject: |
Same lug pattern, yes. _________________ Mikko
mhart
Joined: 24 Feb 2006 Posts: 170 Location: New York, NY
Posted: Thu Sep 20, 2007 4:43 pm Post subject: |
You'll need to check the offsets...any 15 or 16" wheel with 52.3mm offset that's less than 8" wide or so and the proper bolt spacing should fit no problem (assuming you're at stock ride height...if lowered, you'll probably need spacers and/or fender rolling to fit wider wheels)
For reference, I have an 87 and I have 16" phonedials from a 951...16x7 and 16x8, 52.3mm offset and no rubbing whatsoever (tires are 205/55r15 up front and 225/45r16 in the rear) _________________ '87 924 S - No sunroof and a few modifications |
