remote oil filter and cooler
J1NX3D
PostPosted: Thu Sep 06, 2007 12:21 pm    Post subject: remote oil filter and cooler Reply with quote
I know quite a few guys are running this type of system on their n/a's. Can anyone whith any experience please check out this thread on my friends car and pm me any advice?
http://www.gpforums.co.nz/thread/283592/?s=
TIA
'86 944
PostPosted: Thu Sep 06, 2007 12:56 pm    Post subject: Reply with quote
I installed an oil cooler with remote filter mount on my NA some time ago. I have since removed it because the lines that came with it weren't steel braided, and one of them managed to get punctured somehow. I've been busy with other priorities on other cars, so buying $200 of line and fittings to plumb it in correctly on the NA just isn't that high on the list right now. In any event, I did NOT see any drop in oil pressure after installation. But I did notice about a 20-30C degree drop in the oil temp (I also installed an oil temp sender and gauge at about the same time).
PostPosted: Thu Sep 06, 2007 10:04 pm    Post subject: Reply with quote
No, there's no reason adding a cooler should reduce in a loss of oil pressure - sounds like somebody F'd up the plumbing. I'm running -10 hose for my cooler, works fine. Go big or go home; I run an 8x11.5" cooler, and need it. Street cars might be OK with smaller, sure.
I do run an oil t-stat, though I'm pretty sure it's not necessary in my case.
Sounds like a lot of confusion there about plumbing; do any questions remain?
J1NX3D
PostPosted: Fri Sep 07, 2007 7:20 am    Post subject: Reply with quote
No, not about the setup. hes really pleased with the info so cheers to ideola and 924RACR for that!!
hes now asking if anyone in NZ can get 12 sized oil coolers for cheap? lol!
'86 944
