Tiny
Posted: Wed Aug 29, 2007 1:17 am Post subject: Who here has rebuilt their WUR? |
With a timing light, I've set the timing to factory spec, and i seem to be having similar symptoms to
http://www.924board.org/viewtopic.php?t=23030 (titled "fuel pressure issue 924")
After a minute of running from a cold engine, engine revs gradually drop till car stalls. (its an auto)
Can restart no problem. This happens until the engine is at running temp, regardless of where the ign. timing and fuel mix are set. (also just to say, I know these are set correctly at the moment.)
Once at running temp, everything is fine - runs smooth and Im able to set timing and reset idle speed with no probs.
Have replaced all suspect vacuum hoses,intake boots, replaced the AAV too.
Other board members have mentioned the WUR. I want to know if anyone here has successfully opened/cleaned/rebuilt their WUR as Mike924 says the metal valve can jet jammed. Any major pitfalls when undertaking this job?
I dont want to be taking it apart to find out that putting back together is going to be as tricky as rebuilding the fuel distributor.
Thanks All
Tiny _________________ *****1981 - 924 - Auto - London, UK****** |
Posted: Wed Aug 29, 2007 10:38 am Post subject: |
Try disconnecting the wires to the WUR and allowing it to warm up from the engine heat only.
Same for the AAV.
See if this makes a difference.
Also an auto should be set to idle speed while in drive. _________________ Porsche 924 1984 (UK import) NA
Posted: Wed Aug 29, 2007 3:59 pm Post subject: |
Special T Auto. . . _________________ Toofah King Bad
Posted: Wed Aug 29, 2007 5:14 pm Post subject: |
It's easy enough to open up the WUR; there's just a screw in each corner. As the screws are Loctite'd, you need to apply quite a bit of force, so careful application with a well-fitting tool is required.
Once inside, things come out quite easily. There's an electircally-assisted bi-metallic strip and a simple 'plug'-type valve. On mine, the plug was rusted to the body (a ~1-inch steel insert in the die-cast case).
I'm sure if the rust was cleaned off, the thing would work fine. The trouble is that the parts are very small, so I'm not sure just how easing cleaning the rust off would be. I have to admit that when I took mine apart, I dropped the plug and I've never seen it since!
On a scale of 1 to 10 (fuel dist. = 10), I'd say 6. _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
Posted: Wed Aug 29, 2007 5:20 pm Post subject: |
Of course, the other option is to replace. WURs come up pretty regularly on a 'certain well-known aution site', but as this seems to be a common failure mode of WURs (at least in our damp climate ), quality can be iffy (especially if the car it's from has been sitting for any length of time.)
I bought one new from Euro Car Parts (£120 including the dreaded), but I see the 924 ones aren't listed anymore. You'd have to risk a Golf GTi unit... _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
Posted: Wed Aug 29, 2007 5:27 pm Post subject: |
Oh - and, before opening the WUR up, check the resistance of the heating element. It should be around 100 ohms iirc, but if it's open circuit, the element's gone. You could attempt to repair a broken element (I know Smoothie would, just for the hell of it ), but on the same 1 - 10 scale, that would be a 15! _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
Benino
Posted: Thu Aug 30, 2007 1:27 am Post subject: |
| Mike924 wrote: | It's easy enough to open up the WUR; there's just a screw in each corner. As the screws are Loctite'd, you need to apply quite a bit of force, so careful application with a well-fitting tool is required.
On a scale of 1 to 10 (fuel dist. = 10), I'd say 6. |
I'll agree with this although I've never taken a fuel distributor apart. The WUR is not that complex. You just need to take it apart carefully so that you don't lose anything. I cleaned mine up and put it back together. Made a huge difference in how well my car ran. I didn't replace any seals or parts. I just cleaned everything up and put it back together. _________________ 1980 Porsche 924 N/A USA
1980 Porsche 924 turbo USA
1987 Porsche 944S USA |
Buwani 931
Joined: 31 May 2004 Posts: 308 Location: Napa California
Posted: Thu Aug 30, 2007 1:45 am Post subject: |
I ran across this a while back. Mine is a bit different but this has the basics of it
http://www.bmw320i.com/library/howto/WUR%20Servicing.pdf
I think the hardest part in the mounting and unmounting to the block. I did find a allen wrench that I had been missing while I was down there.
Shawn _________________ 1980 931
That's thirty minutes away. I'll be there in ten. |
Tigger937
Posted: Thu Aug 30, 2007 3:27 am Post subject: |
Excellent!!! _________________ 1981 931 (Concours)
1982 931 (Daily Driver)
"Think outside the box" |
Tiny
Posted: Mon Sep 03, 2007 1:21 am Post subject: |
Hi Guys - thanks for posting that "How to" - very cool
Just removed and opened mine to find this mess... -
so question....Whats in my WUR?!?
968rz
Joined: 21 Aug 2006 Posts: 537 Location: S. E. Wisconsin
Posted: Mon Sep 03, 2007 1:38 am Post subject: |
| Tiny wrote: |
Tiny |
A quick guess would be water, but I could be wrong. _________________ Rick
93 968 coupe Amazon Green 4spd Tip (my DD) |
Posted: Tue Sep 04, 2007 2:20 pm Post subject: |
I'll see that water and raise you a pile of rust. _________________ Toofah King Bad
968rz
Posted: Wed Sep 05, 2007 12:47 am Post subject: |
High stakes playa eh? question is how would water get there; time for some fuel conditioner like Heat (to remove water from gas) _________________ Rick
Posted: Wed Sep 05, 2007 1:39 am Post subject: |
I'd have said condensation if it were an even distribution all over, but the white stuff coming up just to a certain level like that has me thinking it was leaking fuel internally. _________________ "..it's made in Germany. You know the Germans always make good stuff."
Posted: Wed Sep 05, 2007 1:42 am Post subject: |
Fuel can't build up inside, because the bottom plate has a hole in the middle.
I'm pretty sure condensation is the culprit. _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
