slight vibration in gearshift lever lower rpm
B
PostPosted: Fri Aug 17, 2007 8:59 am    Post subject: slight vibration in gearshift lever lower rpm Reply with quote
I had recently changed my shift lever bushings on my '79 na and in spite of the trouble I had getting to them - dismantling and putting it back together seemed to go fairly smooth. On my first test run, while thoroughly enjoying shifting and having the gear shift stay in position, I noticed a vibration that starts at about 1400 and stops at about 1800 rpm. First I noticed that my new exhaust set up was off line, so I adjusted that and the vibration was still there. It occurs in neutral or in gear, with the clutch in or out. I don't know if this vibration was there before I fixed the bushings because there were no bushings left when I got in there. So this may have been there all along and just showed up now because things are actually firmly connected. It does not seem to affect anything now when I am driving, but I want to be sure this isn't something major that will blow up in my face later when I am far from home base.
Any thoughts? Ideas?
thanks
B
1979 924 n/a
BAE turbo
5-speed snailshell
B
PostPosted: Sat Aug 18, 2007 5:32 am    Post subject: Reply with quote
does anyone think it could be engine mounts? shaft bearings?
thanks
B
1979 924 n/a
BAE turbo
5-speed snailshell
PostPosted: Sat Aug 18, 2007 6:31 am    Post subject: Reply with quote
I think it could be engine mounts or driveshaft bearings! Or, something else entirely. . .
I think there is a procedure in our Tech Section or in Haynes that allows you to measure the mount with a home-made caliper to see if it has collapsed. That would be a worthy first step.
rasta
B
PostPosted: Sat Aug 18, 2007 6:58 am    Post subject: Reply with quote
It feels like something from the front just the way the vibration comes on, that's why I thought maybe after getting everything moved around and then hooked back up maybe a mount that was already bad showed up - - ?
any ideas on a decent source for these mounts? I looked at performance products but I didn't know if any of you knew of a better possibly more reasonable option?
thanks very much
B
1979 924 n/a
BAE turbo
5-speed snailshell
Buwani 931
PostPosted: Sat Aug 18, 2007 7:31 am    Post subject: Re: slight vibration in gearshift lever lower rpm Reply with quote
B
Since it is at the same rpm's , in neutral or in gear and clutch in or out, It would more than likely have to be from the clutch forward drivetrain wise. Still could be exhaust. New Exhaust done at the same time or previously?
Shawn
That's thirty minutes away. I'll be there in ten.
B
PostPosted: Sat Aug 18, 2007 8:21 am    Post subject: Reply with quote
yes the exhaust was done just before all of this, then taken down to do this
I am not too familiar with the clutch and forward drivetrain wise - what should I look for, or at?
I know when I was working on the shift lever I moved the trans around while it was connected - but I didn't force it too much in any direction, just as much as it would move easily.
thanks
B
1979 924 n/a
BAE turbo
5-speed snailshell
johnathan1
PostPosted: Thu Nov 01, 2007 8:41 pm    Post subject: Reply with quote
AFAIK, my shifter bushings are all still good, my shifter feels very notchy, and always stays in place when in gear. I also noticed that my shifter vibrates quite a bit right around 3500RPMs...above and below that it doesn't really vibrate at all...I just assumed it was normal?
-1977 924, 4-Spd...Gone
-1987 Toyota Supra Turbo, Pearl White, BPU, 300RWHP @ 10psi.
-1989 Mercedes-Benz 300SEL
WARNING: MAY CONTAIN TRACES OF AUDI OR VW!
B
PostPosted: Fri Nov 02, 2007 6:19 am    Post subject: Reply with quote
I'm sorry I'm still learning some of these abbreviations - what is AFAIK?
my vibration occurs at a lower rpm consistently 14-1800. I thought I read in a post that the engine damper(?) might also be a culprit - I remember mine not looking too good when I was under there in the spring so I may check that too.
thanks
B
1979 924 n/a
BAE turbo
5-speed snailshell
Neil924
PostPosted: Fri Nov 02, 2007 6:54 am    Post subject: Reply with quote
thanks
B
As Far As I Know
PostPosted: Fri Nov 02, 2007 7:14 am    Post subject: Reply with quote
Neil924 wrote:
As Far As I Know
True, AFAIK.
PostPosted: Fri Nov 02, 2007 8:27 am    Post subject: Reply with quote
or..swiw.
( so weit ich weis...)
