garyw
Joined: 17 Jan 2003 Posts: 38 Location: Winnipeg, Manitoba, Canada
Posted: Sun Aug 12, 2007 9:52 am Post subject: Looking for help with clutch removal |
I am replacing the clutch in my 1980 931. I have removed the clutch bellhousing and came across this.
[img]http://uk.pg.photos.yahoo.com/ph/gweinheimer/detail?.dir=804e&.dnm=9e35re2.jpg&.src=ph[/img]
Here is a link of the photo does not appear
I does not look like the picture in the manual or the PET and has no visible clutch/pressure plate assembly. Any suggestions on what to do next to get at the clutch? Do I remove the starter ring? DO I need a special tool or do I need an allen key strong enough? I have already bent 2 allen keys on the nuts.
Thanks for any advise. |
scotthusky89
Joined: 13 Jul 2007 Posts: 78 Location: south wales uk
Posted: Sun Aug 12, 2007 10:09 am Post subject: |
yep when i stripped the engone out of my 931 and changd the clutch mine looked like that one u have there and i took it off with a strong allen key bit once u undo the bolts thers 9 i think the starter ring comes off then the pressure plate comes off after and im not sure if there are one or two bolts under th starter ring i dont think there is but ? but once u undo them the plate should come off and then the clutch will be loose _________________ hi everyone nice to see and talk and hear from u
82 924turbo s2 english rhd verson |
garyw
Posted: Sun Aug 12, 2007 11:00 am Post subject: |
| thanks. |
-nick
Posted: Sun Aug 12, 2007 11:19 am Post subject: |
Use a quality allen bit on those bolts and make sure it's seated completely - they can and will strip, then you're in for a world of hurt drilling them out with the engine installed.
You'll need a 3/8" drive bit and a matching 3/8" torque wrench to torque them down correctly when you reinstall anyway.
Be forewarned - the pressure is fairly heavy and will fall right on your chest when the last allen bolt comes out, along with the clutch disk. _________________ 1980 931S
1991 964 C4 Cabriolet |
Posted: Sun Aug 12, 2007 11:29 am Post subject: |
Yeah as you catch the pressure plate with both hands, the clutch disc will fall out and damage itself. Don't ask.
If you have a clutch alignment tool, install it to hold the clutch before removing those bolts. _________________ White 87 924S "Ghost"
jl924t
Joined: 03 Nov 2002 Posts: 214 Location: Surrey, BC Canada
Posted: Mon Aug 13, 2007 9:51 am Post subject: |
Have you found replacement parts yet? _________________ 1980 924 turbo |
garyw
Posted: Mon Aug 13, 2007 3:34 pm Post subject: |
| I have all the parts. I just need to install them. I got everything from Autohaus Arizona. |
924guy
Posted: Mon Aug 13, 2007 10:46 pm Post subject: |
the pics your looking at in the book are probably a for an n/a 924, mine looks the same as yours.... im going to underline nicks post.. echo it, scream it .. go out and get the proper tool. its going to look similiar to this:
even with one, its still easy to strip them out, i stripped one bolt, then broke off a "bolt remover" inside the old bolt carcass, and im still trying to get the darn thing out, two new cobalt bits toasted so far, and several old ones burnt up. one bad bolt... _________________ Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha |
garyw
Posted: Tue Aug 14, 2007 7:48 am Post subject: |
| Too late. The last bolt stripped. I have started to drill it out. The first part was easy, like the metal was soft but am now into some very hard metal. I picked up a bolt remover. I am hoping for the best but have also picked up some expensive drill bits to kep up the drilling. |
Buwani 931
Joined: 31 May 2004 Posts: 308 Location: Napa California
Posted: Tue Aug 14, 2007 11:09 am Post subject: |
I did mine 7-8 years ago and I have lost a few brains cells since then but I somewhat recall stripping one of the heads. I used a bit and drilled just far enough for the head of the bolt to pop off. Left the threads and removed with vice grips after pulling clutch pack back. If you are hitting something hard now, sounds like the ring gear. Has the head seperated from the bolt yet?
Shawn _________________ 1980 931
That's thirty minutes away. I'll be there in ten. |
garyw
Posted: Thu Aug 16, 2007 1:11 am Post subject: |
| Thats pretty much my plan... drill out the head, take off then starter ring, then remove the remaining stud. |
garyw
Posted: Thu Aug 16, 2007 1:14 am Post subject: |
and no, the head has not yet seperated from the bolt. I needed to take a day off with the family.
Porsche must design their cars to maximize the hours they can charge for repairs. This is way too much work just to replace a clutch. |
Posted: Thu Aug 16, 2007 9:22 am Post subject: |
No they design them to be tanks and last forever. _________________ White 87 924S "Ghost"
garyw
Posted: Tue Sep 04, 2007 7:45 am Post subject: |
I got the nut out and the clutch off so thanks to everyone who gave advice.
The next question is about the release bearing guide tube. The new one I purchased is about .4 cm smaller outer size than the old one. Is this okay? Or will this cause a problem for the release bearing? The drive shaft splines still fit through the tube fine.
Thanks |
Posted: Tue Sep 04, 2007 8:09 am Post subject: |
Does the throw out bearing still fit over the guide tube? _________________ White 87 924S "Ghost"
