Identify that 924/931 part :)
Benino
PostPosted: Tue Aug 14, 2007 8:19 am    Post subject: Identify that 924/931 part :) Reply with quote
Lets see how good u guys are.
This is a segment of a part from my 924 or 931.
Anybody know what it is? I dont think it's that hard but then again I took the picture. if nobody guesses I'll post a little more of the picture.
1980 Porsche 924 N/A USA
1980 Porsche 924 turbo USA
1987 Porsche 944S USA
PostPosted: Tue Aug 14, 2007 8:54 am    Post subject: Reply with quote
Well, it looks like a coaxial cable terminal cover or maybe more than just a cover in that it forms a connection between the center conductor and outer shield/ground. -And it's outside of the passenger compartment, based on the water drops.
Whatever it is, my car doesn't have one (or doesn't have one exactly like it)..
PostPosted: Tue Aug 14, 2007 9:07 am    Post subject: Reply with quote
That's not a coax connector -- we have those here where I work all over the place.
It's a millitary connector, and they range from as few as 3 to on the order of 60 or so contacts from what I've seen lying around here.
We use them on train electronics -- though they're referred to as millitary connectors, they are used elsewhere.
I've never seen that on my car either. It's possible the outside of this cover might be shared between electronic connectors and some other cover though.
78 924 NA
5-lug
RC
PostPosted: Tue Aug 14, 2007 9:20 am    Post subject: Reply with quote
Does look like a BNC coax fitting but more likely a cap rather than a connector.
My guess is a cap on your air conditioner system charge/test valves.
Roger
Benino
PostPosted: Tue Aug 14, 2007 9:58 am    Post subject: Reply with quote
Roger
nope.
I guess I didn't think about the year-specificness of this part. Not really fair to those with a car from a different year.
Here's a pic showing more.
Keaton
PostPosted: Tue Aug 14, 2007 10:46 am    Post subject: Reply with quote
FLUX CAPACITOR!!!!!!!!!!!!! thats were you put the flux in
PostPosted: Tue Aug 14, 2007 12:18 pm    Post subject: Reply with quote
I know I have seen that connector on a 931 before, though exactly where I cannot recall,
though that box appears to do with the ign system, and that would be a test port with an electrical pinout on it.
3 928s,
RC
PostPosted: Tue Aug 14, 2007 12:40 pm    Post subject: Reply with quote
Benino wrote:
Or a car from a different part of the planet!
Dont know if it is specific to 931s or California/ USA spec vehicles but there sure isn`t one on mine in OZ and WTF it is, isnt needed here to make it GO.
Roger
Slam
PostPosted: Tue Aug 14, 2007 1:46 pm    Post subject: Reply with quote
DITC component that sits on inside front headlight pocket/driver's side? Can't recall exactly what it's called. Kinda late...
'84 944 - kid blew motor
'83 944 - resting comfortably. For 12 years
'87 944 - sideswiped by trucker
'80 924 - gone
'78 924 - gone
'77 924 - rusting comfortably
924guy
PostPosted: Tue Aug 14, 2007 1:52 pm    Post subject: Reply with quote
those are definitely bayonet nut connectors , (or BNC's) with terminator caps on them. they are used most commonly for video feeds, but can be used in many other applications where a locking connection is needed. the terminator caps loop the signal in most cases, but not always.
ive seen them used on radio signal amplifiers, as oscilloscope connection ports, and a host of other things besides video, even clocks.
whatever it is, i haven't found it on my 82...
Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha
Benino
PostPosted: Tue Aug 14, 2007 2:23 pm    Post subject: Reply with quote
I do like the Flux Capacitor answer. . . but I think Lizard Wins. It is the ignition module on the 1980 931. I don't have the picture on me now, but the bottom 1/2 pretty much looks like the normal ignition module on the rest of the 924 cars. I'll post it in the morning. So yeah it is the ignition module, but this car does not have DITC.
I won't make the next one so year specific. Anyone else have a mystery 924 part to post a picture of?
RC
PostPosted: Tue Aug 14, 2007 2:49 pm    Post subject: Reply with quote
OK, I found it now.
How come yours is blanked off?
Mine is connected to the oscillating sprocket valve.
Doesn`t your car have one?
Roger
PostPosted: Tue Aug 14, 2007 3:45 pm    Post subject: Reply with quote
Um, no Porsche left Stuttgart with that cheap keychain material dangling from it.
rasta
Buwani 931
PostPosted: Tue Aug 14, 2007 3:56 pm    Post subject: Reply with quote
I'm going with Fetzer valve. Those connectors hold the ball bearings in.
Judging by the gunk on it, you should clean it with some 3-in-1 oil and some gauze pads.
Fletch
That's thirty minutes away. I'll be there in ten.
PostPosted: Tue Aug 14, 2007 5:10 pm    Post subject: Reply with quote
It's a modified ignition ECU with a pair of BNC connectors (with dust-caps fitted), most commonly used in coax networking installations, also find common use in RF and video applications.
One other common use of BNC connectors is as input connectors to oscilloscopes; so I'm guessing that's their purpose here: to allow someone to hook up a 'scope to monitor the ignition pulses. I'd guess one's connected to the signal from the distributor and one's the ECU output to the coil.
Am I right?
