Setup Advice
PostPosted: Tue Aug 07, 2007 7:59 am    Post subject: Setup Advice Reply with quote
Car is understeering a bit. Here is a pic of big body roll in a 3rd gear corner.
Springs are 140, sway bar is 23mm. Changes?
rasta
PostPosted: Tue Aug 07, 2007 8:06 am    Post subject: Reply with quote
You can probably gain a bit more control with alignment changes - what're your current settings?
But ultimately, to significantly reduce that body roll, you need to increase your roll rate, period - either stiffer sways or stiffer springs/t-bars. Springs and t-bars will probably be cheaper, at least for new parts, but more work to install.
genikz88
PostPosted: Tue Aug 07, 2007 9:10 am    Post subject: Reply with quote
That's not too bad actually. Here is my '88 924S with 400lb front springs and 30mm torsion bars (stock front anti-roll bar and Welt 22mm rear). Your car isn't leaning much farther.
As far as understeering, maybe try playing with your tire pressures. Also, an alignment is crucial. Lastly, a bigger rear anti-roll bar will induce more oversteer, which in my case helps the car rotate and makes understeer much less of a problem.
Chris
'88 924S
steeny
PostPosted: Tue Aug 07, 2007 10:11 am    Post subject: Reply with quote
Rasta, for that corner, you could always try putting the driver on the correct side of the car.
1978 924 N/A
she's gone.....
PostPosted: Tue Aug 07, 2007 11:59 am    Post subject: Reply with quote
Are you implying that my personal mass is influencing Shaggy's handling?
geni, you got 15s up front and 16s in the rear? Crazy!
PostPosted: Tue Aug 07, 2007 12:32 pm    Post subject: Reply with quote
Until you get it corner balanced....
genikz88
PostPosted: Tue Aug 07, 2007 3:02 pm    Post subject: Reply with quote
Must be an illusion...they're all 15x7
Chris
'88 924S
John Brown
PostPosted: Thu Aug 09, 2007 5:57 am    Post subject: Reply with quote
Put the 968 19mm adjustable (some) in the rear. Paragon sell them. Not perfect but about all you can do without spending some semi-serious money. Assuming you have the 'standard' 14mm you could also install an 18mm. Someone should have one for the low side of $100.
John
80 931 - #931 44Cup
99 Escalade - tows track cars
PostPosted: Thu Aug 09, 2007 7:27 am    Post subject: Reply with quote
i have the same understeering problem here...i guess that you could trick it a bit by deflating the front tyres a bit....at least thats what i'm thinking now after a few beers
!tom
PostPosted: Thu Aug 09, 2007 8:17 am    Post subject: Reply with quote
I'd rather air up the rears than deflate the fronts.
That does nothing for the body roll, which will slow the handling response and increase weight transfer.
Tire pressure is a fine tuining aid -- it doesn't replace sway bars and springs.
Street tires can be safely run far above their maximum pressure rating, but if you lower the pressure much, they start to handle poorly.
78 924 NA
5-lug
PostPosted: Thu Aug 09, 2007 9:06 am    Post subject: Reply with quote
I am running that bar currently, set on full stiff, with an M471 23mm up front.
StienbargerR
PostPosted: Thu Aug 09, 2007 9:45 am    Post subject: Reply with quote
wouldn't stiffening the rear just make it understeer more?
Ryan
1978 924 NA
!tom
PostPosted: Thu Aug 09, 2007 9:55 am    Post subject: Reply with quote
Nope.
As discussed elsewhere, a stiffer rear sway bar will loosen the car, or give it oversteer, depending on the terminology you want to use.
78 924 NA
5-lug
StienbargerR
PostPosted: Thu Aug 09, 2007 10:12 am    Post subject: Reply with quote
oh. I stand corrected.
Ryan
1978 924 NA
PostPosted: Fri Aug 10, 2007 9:30 pm    Post subject: Reply with quote
Hm. As Scott said, check your alignment, maybe try som more track friendly settings. My car was very netutral before, but as the tires started to wear out it passed over to the oversteer side. Just a little bit, but still pretty fast.
The key is to have real rubber on your wheel. If you have planned to track drive more than one time i suggest buying a set of "r-compund" tires, not really sure what you call them. Really stiff sidewalls helps alot, and they do not overheat. Current set up is about -3 degrees of negative camber. After i changed camber i gained ALOT of front end grip. But i´m to lazy to change rear. Its about -1.2 degrees. That is a cheap way of getting fast around the tracks.
