Other front caliper 924
Dutch924-racer
PostPosted: Mon Jul 23, 2007 5:07 pm    Post subject: Other front caliper 924 Reply with quote
I have an 924 from 1980. My front calipers need replacing. I don't want to change to 5 lug 944 brakes.
What options are there ?
937 trackday car
Series 2 engine
951S turbo and intercooler
Fast road camshaft
PostPosted: Mon Jul 23, 2007 6:32 pm    Post subject: Reply with quote
IIRC the audi 100 has 4x108 and has similar calipers...but i cant tell you that they are identical.
PostPosted: Mon Jul 23, 2007 9:09 pm    Post subject: Reply with quote
According to this, the Audi 100 series from '75-'77 uses the same caliper - http://www.partsamerica.com/ProductGuide.aspx?mfrcode=BEN&mfrpartnumber=R46285
PostPosted: Mon Jul 23, 2007 10:23 pm    Post subject: Reply with quote
Aren't they also the same as the 944/M471/5-lug rear calipers?
Dutch924-racer
PostPosted: Tue Jul 24, 2007 1:15 am    Post subject: Reply with quote
no, the are different
937 trackday car
Series 2 engine
Fast road camshaft
Last edited by Dutch924-racer on Mon Dec 10, 2007 3:58 am; edited 2 times in total
PostPosted: Fri Aug 10, 2007 5:24 pm    Post subject: Reply with quote
ok so i've dont research and tests:
The 924 4lug front caliper is NOT the same as the rear 5lug caliper. They look almost the same but they are different.
I tryed to use a front 4lug caliper on the rear arms and the disc is too big and to thick.
jurasT
PostPosted: Sat Aug 11, 2007 1:44 am    Post subject: Reply with quote
You can use Audi calipers and they are a bolt on. I used them with VW passat brak carriers (the same brake disc diameter as 924 and the same disc thickness).
Now I also have Audi A4 calipers at the rear with Audi 100 4x108 discs but fitting them was not as easy as the front.
http://porscheclub.pl/imprezy_zdjecia/2007_borsk/600/076.jpg
PostPosted: Sat Aug 11, 2007 3:04 am    Post subject: Reply with quote
nice looking car...why dont we euro guys set up a meeting somewhere nice ??
PostPosted: Sat Aug 11, 2007 3:36 am    Post subject: Reply with quote
jurasT, we would all be interested in more details about this conversion...would you be willing to write up a basic how-to, that would include the required parts and modifications?
