andy 931
Joined: 20 Dec 2006 Posts: 14 Location: aberdeenshire scotland
Posted: Sun Jul 22, 2007 2:11 am Post subject: advise wanted |
hi,i am looking for a bit of advice. i have recently purchased a 85 2.0 na
with the intention of building a lightweight fast road car for a bit of fun at the weekends . as practicality is not important with this one it is completley stripped out (ever removed the underboady sealant on one of these? its caked on, a 25kg saving tho!)
i have fitted fibre glass bonnet, wings, front pannel and replaced the glass with poly carbonate windows. trying to get weight down to approx 800kg!
i want a bit more power but without the extent of engine swaps or capacity increse . im looking for 140 bhp +
any suggestions woul be appreciated.
thanks
andy _________________ 1980 924 turbo blue/silver
1986 924s red
1988 944s black
1985 924 na blue |
Posted: Sun Jul 22, 2007 4:13 am Post subject: |
to get 140bhp NA out of this car,
rebuild the engine with a turbo head, and custom pistons with say 10.5:1 or 11:1 CR, stage II camshaft, add ITBs, and convert to standalone EFI like megasquirt or VEMS _________________ 3 928s, |
andy 931
Posted: Sun Jul 22, 2007 8:21 am Post subject: |
is a 931 head realy required to reach around 140bhp? _________________ 1980 924 turbo blue/silver
1986 924s red
1988 944s black
1985 924 na blue |
Scorpio
Posted: Sun Jul 22, 2007 10:23 pm Post subject: |
hey Lizard would that increase to 140hp require a change to the tranny..gearbox etc..breaks aswell or can the stockNA handle it?..mainly asking for road worthy reasons.. _________________ 1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
GT BASED CUSTOM BODYKIT
Brisbane , Australia
Think mean think fast
all youll see is
my Porsches Arse!!! |
Joined: 29 Jul 2001 Posts: 9137 Location: Royal Oak, MI, USA
Posted: Sun Jul 22, 2007 10:35 pm Post subject: |
I don't think it's necessary; I'm creeping closer to 130hp crank (on the racecar) with stock head and CAM, little more than a header. The cam is a big issue with these cars, apparently you can really free up a lot of power if you reprofile. Frankly, I hold out some hope that I can maybe, eventually, with some expert direction, get this thing nearer 135hp.
There's other internals stuff done to my motor, admittedly, but it's a pretty limited rebuild, by the rules; 9.5:1 CR, .040" overbore, Total Seal rings, and balanced and blueprinted lower end. No real tweaking of the head allowed, just a minor port match and a performance valve job. I do have a cam advance key, 4 degrees, but a proper cam grind should eliminate the need for that.
So my recommendations would be a good header and exhaust, rebuild and bump the compression to maybe 10.5:1 (to make it manageable with street gas), definitely balance and lighten up the rotating assembly and flywheel a bit (or Al. Fidanza flywheel). Performance valve job, some port-matching, not sure I'd go whole hog on porting the entire head though... larger throttle body... and yes, I agree, some kind of modern programmable EFI conversion - I'm going to do a Megasquirt, eventually.
Then some dyno tuning time.
I expect a fresh rebuild on the trans and torque tube may be needed, but 140 isn't THAT much... if you did find it to be a problem, I'd switch over to a 944 box and torque tube - that's designed for 150hp stock (at least in US trim, probably more over there). _________________ Vaughan Scott
Vince Ponz
Posted: Sun Jul 22, 2007 11:37 pm Post subject: |
Mild cam, headers, Euro pistons which you have, MSD ignition, Webers and I think I have about 135. I lightened the car also. You started with 125 hp and the stock euro pistons.
Not hard to reach. _________________ "Never let them see you sweat"
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock |
andy 931
Posted: Mon Jul 23, 2007 12:42 am Post subject: |
cheers guys, as with regards to compretion increse, whats your vews on skimming the block buy 2mm,1 mm being the norm. i have heard of this being done but at what cost on reliabilty? _________________ 1980 924 turbo blue/silver
1986 924s red
1988 944s black
1985 924 na blue |
Posted: Tue Jul 24, 2007 4:57 am Post subject: |
Where did you get the fibreglass panels from, Andy? Is the qualiity any good? _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
Posted: Tue Jul 24, 2007 7:55 am Post subject: |
scorpio, 924Racr aka Vaughan answered your questions nicely.
If you are going to do it, imo do it fully. You may get more than 140bhp out of what I have suggested but it is hard to say. _________________ 3 928s, |
seanski44
Joined: 13 Mar 2006 Posts: 532 Location: Nottingham UK
Posted: Tue Jul 24, 2007 6:06 pm Post subject: |
or get your N/A head modded to remove that 'corner' the air has to go round!!
now, my knowledge is limited about these things, but don't go for HP and sacrifice torque!!  _________________ 1998 BMW Z3 2.8 arctic silver & red
1981 168HP 931 S2 blue/tan leather - SOLD
1985 121HP 924 2.0l na modded - SOLD!
1992 968 lux SOLD
1989 944 2.7 lux SOLD |
