Fuel Pump Check Valve
Buwani 931
PostPosted: Sun Jul 15, 2007 9:48 am    Post subject: Fuel Pump Check Valve Reply with quote
I have been working on the fuel system and suspect a faulty fuel pump check valve. The external pump is a bosch 0580254984. Here is what is between the pump and the hose.
Is this where the check valve is suppose to go? I was very careful taking it apart as I thought there would be a spring and ball inside but nothing. Is the check valve down in the long hex part of the pump? Am I looking in the wrong place for the check valve?
I bet smoothie would have a photo of it but his photos have migrated to some new server and I could not access.
Shawn
That's thirty minutes away. I'll be there in ten.
PostPosted: Sun Jul 15, 2007 11:11 am    Post subject: Reply with quote
Sounds like your check valve is built into the pump. Don't know if it is rebuildable or not, but gives you a good excuse to dump the Boswch unit for Pierburg.
Buwani 931
PostPosted: Mon Jul 16, 2007 6:44 am    Post subject: Reply with quote
I think this explains it.
http://www.connactivity.com/~kgross/FAQ/tb/tb.20.8002.html
If I understand this correctly, the original pump had an internal check valve. Replace the fitting like I have with a check valve without having to replace the pump.
Shawn
PostPosted: Mon Jul 16, 2007 2:21 pm    Post subject: Reply with quote
Cool, let us know how it works out.
Buwani 931
PostPosted: Mon Aug 06, 2007 6:13 am    Post subject: Reply with quote
I got a check valve, Bosch 1587010004 and it fits perfect. Still have issues but it does replace the original fitting.
Shawn
johnathan1
PostPosted: Thu Dec 27, 2007 10:50 am    Post subject: Reply with quote
Can I install an external check valve on my 77 NA? Or does mine have a different type of pump?
-1977 924, 4-Spd...Gone
-1987 Toyota Supra Turbo, Pearl White, BPU, 300RWHP @ 10psi.
-1989 Mercedes-Benz 300SEL
WARNING: MAY CONTAIN TRACES OF AUDI OR VW!
Buwani 931
PostPosted: Fri Dec 28, 2007 2:55 am    Post subject: Reply with quote
I cant say for sure but I think it is the same. Autohauz az shows the same part number for the 78. Does the 78 have female threads on the pump or a banjo fitting?
My problem ended up being elsewhere. You should replace the pressure regulator o ring the Ozzie mentioned in the other post. I think thats where my problem was. I did the warm up regulator at the same time, could have been there.
Shawn
johnathan1
PostPosted: Fri Dec 28, 2007 4:49 am    Post subject: Reply with quote
Ok thanks. Do you have a part number for that o-ring, or know what size it is? Is there any special material it should be made out of?
And do you mean you replaced the warm up regulator completely?
Buwani 931
PostPosted: Fri Dec 28, 2007 9:41 am    Post subject: Reply with quote
I dont have a number for your oring, mine is a little different setup and I dont know if the early NA is the same. Mine used an industry number 008 and 011.
A Buna-nitrile oring will stand up to fuel. I used a Duro 70 (hardness) and it seems to be holding up fine.
I did replace my WUR as it had a broken spring inside. As I was waiting for my WUR, I replaced the orings in the pressure regulator. Not sure which fixed it but it's fixed.
Shawn
