Fuel Injectors
KMC MK
PostPosted: Tue Jun 12, 2007 4:06 am    Post subject: Fuel Injectors Reply with quote
I am looking to replace the fuel injectors on my Porsche 924 N/A (non turbo) 2 ltr.
The car is an early 1980 model (so its on border between 1979 and 1980 I think)
The cars chassis number is 92A0414211
Paragon Products in the US had the following Bosch
Product Code: PP0.437.502.013
Description
Fits 924 76-80*
*early 1980, to VIN #92A0430201
But Eurocar parts (in UK) has the following injectors:
BOSCH n/a 431330050 INJECTOR 924 77-79
injector 77-79 models £29.00
BOSCH n/a 431440110 PETROL INJECTOR VW/AUD/POR/VOL GO/JE/SC/A100/ACOU/A200/924/240/740
injector 80-85 models
Which injector should I buy of the three listed above?? ? Is there a difference?
Chrenan
PostPosted: Tue Jun 12, 2007 4:21 am    Post subject: Reply with quote
If you have the braided steel fuel lines running to your injectors, you need the early injectors.
If you have solid steel changing to rubber covered plastic fuel lines running to you injectors, you need the late injectors.
What injector lines do you have?
KMC MK
PostPosted: Tue Jun 12, 2007 4:22 am    Post subject: Reply with quote
they are solid steel lines connected to the injectors......
Martijnus
PostPosted: Tue Jun 12, 2007 4:49 am    Post subject: Reply with quote
I got both types in my car some people....
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
Tigger937
PostPosted: Tue Jun 12, 2007 4:53 am    Post subject: Reply with quote
Well, at least you can say you have the "right" ones!
1981 931 (Concours)
1982 931 (Daily Driver)
"Think outside the box"
jimcarver
PostPosted: Tue Jun 12, 2007 11:40 pm    Post subject: Reply with quote
If it is the late ones you need, its worth giving these a go.
It ended up costing me about £50 delivered.
http://cgi.ebay.com/ebaymotors/Porsche-924-80-82-2-0-fuel-injector-set-NEW_W0QQcmdZViewItemQQcategoryZ33554QQihZ007QQitemZ170121236957QQrdZ1QQsspagenameZWDVW
1984 NA Guards Red
