Dans931
Posted: Fri Feb 03, 2006 5:19 pm Post subject: 931 fuel filter |
It appears that 931 fuel filters have the same fittings on either end. Both my 80 and 82 were this way and both cars had filter installed backwards when I bought them. So, always make sure the arrow on the new filter points toward the fuel distributor.
Daniel |
Posted: Sat Feb 04, 2006 4:22 am Post subject: |
| Quote: | | make sure the arrow on the new filter points toward the fuel distributor. | By that, you mean pointing toward the rear of the car, right?
Right.  _________________ "..it's made in Germany. You know the Germans always make good stuff."
jnbm
Posted: Fri Jun 08, 2007 2:31 pm Post subject: |
| what????are you guys sure? mine points to the front of the car?...should i switch it? have i been messing up my car driving it with the filter backwards? |
Posted: Fri Jun 08, 2007 2:34 pm Post subject: |
dont swap ends with the one that is in there, replace it with a new one, but the arrow is supposed to point backwards _________________ 3 928s, |
jnbm
Posted: Fri Jun 08, 2007 3:21 pm Post subject: |
| will do lizard. will do. |
Joined: 29 Jul 2001 Posts: 9076 Location: Royal Oak, MI, USA
Posted: Fri Jun 08, 2007 9:46 pm Post subject: |
Yeah, that's a common misconception - the '81 931 I just picked up had the same problem.
Of course, if you just turn it around, all the junk that it's been catching will now be flushed into your fuel distributor!!!  _________________ Vaughan Scott
Posted: Sat Jun 09, 2007 1:24 am Post subject: |
Still waiting to hear Dan weigh in on what he was considering "backwards". . . _________________ Toofah King Bad
Buwani 931
Joined: 31 May 2004 Posts: 308 Location: Napa California
Posted: Sat Jun 09, 2007 6:25 am Post subject: |
The way I understand it is
Left hand drive it points toward the rear of the car.
Right hand drive, points to the front.
Follow the line, left hand drive goes back, along the firewall, then forward to fuel distributor.
Right hand drive goes directly foward to fuel distibutor.
80 turbos had a split where some used both female fittings and some used one male one female but in left hand drive, either will point towards the rear of the car. _________________ 1980 931
That's thirty minutes away. I'll be there in ten. |
flosho
Posted: Thu Jun 14, 2007 4:32 am Post subject: |
Where is the cheapest place to get a 931 fuel filter from, that doesn't take forever to ship? _________________ [This Space For Rent] |
