931 fuel filter
Dans931
PostPosted: Fri Feb 03, 2006 5:19 pm    Post subject: 931 fuel filter Reply with quote
It appears that 931 fuel filters have the same fittings on either end. Both my 80 and 82 were this way and both cars had filter installed backwards when I bought them. So, always make sure the arrow on the new filter points toward the fuel distributor.
Daniel
PostPosted: Sat Feb 04, 2006 4:22 am    Post subject: Reply with quote
By that, you mean pointing toward the rear of the car, right?
Right.
jnbm
PostPosted: Fri Jun 08, 2007 2:31 pm    Post subject: Reply with quote
what????are you guys sure? mine points to the front of the car?...should i switch it? have i been messing up my car driving it with the filter backwards?
PostPosted: Fri Jun 08, 2007 2:34 pm    Post subject: Reply with quote
dont swap ends with the one that is in there, replace it with a new one, but the arrow is supposed to point backwards
3 928s,
jnbm
PostPosted: Fri Jun 08, 2007 3:21 pm    Post subject: Reply with quote
will do lizard. will do.
PostPosted: Fri Jun 08, 2007 9:46 pm    Post subject: Reply with quote
Yeah, that's a common misconception - the '81 931 I just picked up had the same problem.
Of course, if you just turn it around, all the junk that it's been catching will now be flushed into your fuel distributor!!!
PostPosted: Sat Jun 09, 2007 1:24 am    Post subject: Reply with quote
Still waiting to hear Dan weigh in on what he was considering "backwards". . .
Buwani 931
PostPosted: Sat Jun 09, 2007 6:25 am    Post subject: Reply with quote
The way I understand it is
Left hand drive it points toward the rear of the car.
Right hand drive, points to the front.
Follow the line, left hand drive goes back, along the firewall, then forward to fuel distributor.
Right hand drive goes directly foward to fuel distibutor.
80 turbos had a split where some used both female fittings and some used one male one female but in left hand drive, either will point towards the rear of the car.
That's thirty minutes away. I'll be there in ten.
flosho
PostPosted: Thu Jun 14, 2007 4:32 am    Post subject: Reply with quote
Where is the cheapest place to get a 931 fuel filter from, that doesn't take forever to ship?
[This Space For Rent]
